Help needed as im after either making or having made a rear pannel so require measurements. Any help apreciated :-)
If you can wait until tommorrow I'll measure mine for you.
John
Make it out of alluminium sheet it forms really easy
Cheers john most apreciated. Just after some prices for pannels and keep weight down but if its gunna cost a fortune i may make one from ally but at the moment i may pick up a standard rear pannel and widen it to suit or have one made up not so sure as yet.
It's a lot of work making a narrow panel fit and to have one made as a one off will cost a fortune as will need to make a plug then a mould then
the part from it. You will be better off doing as Austin bloke has said and make it in ali sheet.
[Edited on 1/9/11 by Triton]
I made a rear panel out of three parts. It can be done, is not especially difficult, although it requires patience. It is the cheapest option on a car that costs way more than you think it should in the end. And I may add, quite satisfying work. There are ways of repairing bodges which are inevitable. Many vids and pics available on techniques too.
