hi
and still more questions well 1 more for today cheers
how do i fix the mesh/grill stuff in the nose cone????
cheers steve
Bend it round the back and sikaflex
I glued 4 bits of wood with sikaflex to the back of the nose cone, then used 4 screws and penny washers to fix the grill.
[Edited on 31/10/11 by Slater]
The stikaflex approach worked for, nice a neat to......................
thanks for the info.
is there nothing that stikaflex will not stick.
and it takes ages to wear iy of your hands
Originally posted by jacko
The reason i ask is i know 2 people that had problems with over heating they had mesh / grills like yours and as soon as they removed it the problem went away
zip ties hold mine on. my grille is black and so is the nosecone and zips, so doesn't show.
not the car is not yet a runner but it should not be long i will keep that in mind if it over heats thanks.
steve
I cut mine so it fitted in front, then wrapped the outside with U section rubber and cable tied in place.
