Wipers for a VERY curved screen....
cloudy - 7/11/11 at 10:17 AM
Looking for some good ideas on how to wipe a very curved screen, a traditional wiper would just fly off the screen if you tried to move it at any speed. Any examples of people attempting this?
Thanks,
James
MakeEverything - 7/11/11 at 10:26 AM
Look at the LeMans race cars and the solutions they use on them.
cloudy - 7/11/11 at 10:28 AM
That was my first thought, but it looks like the curve is low enough to use a traditional setup...
James
MakeEverything - 7/11/11 at 10:41 AM
James
I think theyre articulated more to provide more flexibbility.
westf27 - 7/11/11 at 10:49 AM
I think what ever you come up with Rainex solution on the screen would be a big help.
cloudy - 7/11/11 at 10:50 AM
It's purely for IVA reasons rather than practical! The manual doesn't give a very clear idea of how much of the screen needs to be swept...
james
MakeEverything - 7/11/11 at 11:19 AM
james
I would imagine anything within the drivers vision as with cracks or chips.
jabbahutt - 7/11/11 at 11:30 AM
How about the kind of system they self clean cctv cameras with? there as a design for a dome camera years ago where the blade was secured at the top of the dome and the bottom and the blade cured to suit the profile. It them rotated through 360 degreees and dragged the water droplets off.
Just a thought
cloudy - 7/11/11 at 11:35 AM
Interesting thought! Will google that...
MakeEverything - 7/11/11 at 12:02 PM
You might be able to modify or make a track so that the blade parks at the top and wipes downwards. If the blade is curved upwards then the water will move outwards.
designer - 7/11/11 at 12:07 PM
The trick with very curved windscreens is to keep the wiper vertical as it sweeps.
cloudy - 7/11/11 at 12:14 PM
Which would lead down to a design of a tracking wiper rather than a rotating one.... cogs whirring
James
jossey - 7/11/11 at 12:23 PM
if you built a wiper that attaches to a cog wheel vertically then then driven by motors like a normal wiper would that work?
DOES THIS MEAN ANYTHING TO ANYONE OR WAS MY MONDAY am WORK RUBBISH LOL
Its not in perspective but it should work if the cog is the same shape as the window and the axis is set right.
[Edited on 7/11/11 by jossey]
Mr Whippy - 7/11/11 at 01:06 PM
look at the countach wiper arm, a variation on that would probably work though you could do with a rocking motion as well as a side to side
cloudy - 7/11/11 at 02:31 PM
Yep the diagram makes sense - and might work! Just need to think where to park it out of sight...
Can't quite fathom what the countach one is doing, it looks like it's keeping it vertical?
James
nick205 - 7/11/11 at 03:02 PM
Just replaced the wipers on my Passat. Only apparent when you see them off the car, but they are very bowed and achieve a really good pressure right across the screen (albeit a much flatter screen). Might work if you can mount them OK, they have a push button fixing rather than the old hook type. Beware if you buy a pair as they're 2 different lengths.
jossey - 7/11/11 at 03:15 PM
http://www.eurospares.co.uk/userImages/087/Medium/087_037.gif
countach wiper setup......
cloudy - 7/11/11 at 04:14 PM
Found a video http://www.youtube.com/watch?v=vtKsj3tJT5A
Might work if rejigged to keep the blade vertical!
BobM - 7/11/11 at 04:44 PM
Originally posted by cloudyIt's purely for IVA reasons rather than practical!
In which case is leaving the screen off for IVA an option?
cloudy - 8/11/11 at 03:24 PM
I think I have the mechanical solution - just requires a mount oscillated by a normal windscreen motor, and a high angle rose joint at the fixed end... Should countour around the screen and keep the blade angle against the screen constant....
Too barmy?
[Edited on 8/11/11 by cloudy]
jossey - 8/11/11 at 03:45 PM
thats like what i was thinking just your cad work was better than my paint work :O)
cloudy - 8/11/11 at 03:51 PM
It's OK I saw where you were coming from! - by adding the fixed pivot to that it also parks more in line with the body down the side
jossey - 8/11/11 at 03:54 PM
i really like ye work. good stuff.
glad my idea helped i hope :O)
Tiger Super Six - 9/11/11 at 03:48 PM
Look at a lotus elise, pretty much the same shape windscreen you have drawn.
cloudy - 9/11/11 at 03:59 PM
The windscreen is nothing alike! though the drawing doesn't show it too well - think glider cockpit...
James
adithorp - 9/11/11 at 04:39 PM
Cloudy, please tell me, the path you're traveling isn't heading in this direction
scudderfish - 9/11/11 at 06:37 PM
That was my fear when I first saw the thread about seating positions.
MikeRJ - 9/11/11 at 06:52 PM
Too barmy?
It's a nice simple, logical solution if the screen has relatively constant curvature and you can locate the pivot near the center of the radius. If not you could use the same solution but with the addition of a a cam profile to allow the wiper to closely follow the screen contours.
cloudy - 9/11/11 at 07:44 PM
No, nothing like the vindicator!
