Hi
R1 locost very light at front end under acceleration but stable at steady high speed.
Will a front spoiler F1 style help?
If so where could I get one.
And I am sure it would look AWSOME.
Thanks all, John
not really, no, they work at higher speed, and your problem is at lower speeds, so the faster you're going the better it will work.
think suspension set up might be a better place to start
Get the car professionally set up and cornerweighted. No reason a 7 style car should be light on the front end, even a BEC.
Also (and not to patronise you ) but assuming it was OK before you got it , make sure the tyres are at a BEC pressure at the front somwhere around 18psi..
Originally posted by Murphy
Hi
Thanks all, John
I appreciate the replies. Not patronised at all as I am taking in all this on a first time basis. Reading everything I can too.
Cheers everyone
