To Scoop, Or Not To Scoop... (Trike Bodywork)
scootz - 3/12/11 at 02:46 PM
I've been fiddling around with the GRP engine cover that came with the tub to see if I can use it for the trike. It'll need some mods, but will do the trick!
I have a couple of CF engine covers that are gathering dust and plonked one on top to see what it would look like with a big air-scoop.
I think it looks pretty cool, but it would need a fair bit of work to integrate the two of them neatly... does the fact that one's GRP and the other is CF make this process any trickier?
... and finally - opinion please on 'the look' of both options!
Ta!
angliamotorsport - 3/12/11 at 03:00 PM
Hey, that's some machine, like it either way. What engine are you going to use.
gottabedone - 3/12/11 at 03:01 PM
I like the look with both white and black fitted. Can you move the white cover back and over the wheel a bit more? - looks though!
Chippy - 3/12/11 at 03:06 PM
Looks cool with the top air scoop, would need a bit of fairing in but cant see any reason why you shouldn't be able to stick them together with a bit of GRP. Cheers Ray
scootz - 3/12/11 at 03:17 PM
Cheers... it's an engine from the BMW HP2 Sport.
scootz - 3/12/11 at 03:18 PM
Originally posted by gottabedone
Can you move the white cover back and over the wheel a bit more...
Yep... I could extend the rear to cover the wheel. I'm dropping down to 15" wheels (17 pictured), so shouldn't have to lift it too much.
tomgregory2000 - 3/12/11 at 04:31 PM
scooooooop!!!!!!!!!!!!!!!!!!!!!!!!!!
Confused but excited. - 3/12/11 at 04:39 PM
+1
Wheels244 - 3/12/11 at 05:07 PM
+2
stevebubs - 3/12/11 at 05:26 PM
you need 2 rear wheels!!!
Benzine - 3/12/11 at 05:32 PM
Scoop!
matt_gsxr - 3/12/11 at 06:19 PM
My favourite bit;
Originally posted by scootz
I have a couple of CF engine covers that are gathering dust ....
You are a legend.
What are you doing about the roll-hoop as that could affect your choice?
I'd worry about making the vehicle look too tall, but I can't yet visualise the whole vehicle.
Coopz - 3/12/11 at 06:56 PM
Scoop it
scootz - 3/12/11 at 10:09 PM
Cheers fellas! That seems pretty conclusive!
To be fair, the scoop will give me a lot more leeway with the airbox / filter.
welderman - 3/12/11 at 10:44 PM
Scoop looks familiar. Go for scoop Scootz
mcerd1 - 5/12/11 at 01:13 PM
like you say it looks like its a bit of work - but it'll be worth it
r1_pete - 5/12/11 at 01:23 PM
I prefer it without the scoop, it is a striking design, and just doesn't need it in my opinion.
