Finally got round to starting my diffuser/rear undertray. Here's a few pics of the progress so far.
Ramp angles are pretty sensible but the wishbones limit how far back I can take them. It will be mounted with proper fixings not gaffer tape...
You should have a smooth contour rather than a bend where the floor meets the diffuser. They should blend together to get any effect.
thats not generally the case.
I think it is! There must to be a smooth undisturbed flow of air. Any ledge/crease/too sharp a change spoils it.
You can't compare a CART diffuser with our sort of car! That diffuser is concave and works a totally different way!
[img]
[/img]
[img]
[/img]
Looks good fella, just a point of interest. Knowing what you do for a living, do you see any issues with the airflow reattaching to the rear panel as
the diffuser end inline with it? is the space between the 2 enough to prevent this.
Catch up soon, Dan.
Looks top notch.
I can assure you a bend is not a poor design, mine has a bend and was designed by a guy who knows his stuff.
Originally posted by scutter
Looks good fella, just a point of interest. Knowing what you do for a living, do you see any issues with the airflow reattaching to the rear panel as the diffuser end inline with it? is the space between the 2 enough to prevent this.
Catch up soon, Dan.
Some people just wind me up. They have an opinion and run with it, cause some guy somewhere who said he was something, did it. They don't actually have any factual knowledge on the subject themselves or the full story of why a design has bad features because of constraints. And its everywhere, not just this thread. Designer is right, any sharp bend in airflow is bad. And if 30 mm is not a sharp bend for air, the relative velocity must be around 9 mph. If you don't agree, go educate yourself. Although if you look at the amount gained vs. the added weight, you may as well have just put a flat plastic plate under the boot.
Any rear diffuser would surely stop the parachute effect though, so would be beneficial i assume.
