Looking for some metal chrome type trim that can be bent around curves and fitted to exterior of car. Ideally I want to either rivet it on or fit it with clips. Needs to be about 10mm wide. Struggling to find something, all I can find is self adhesive chrome trim which won't do. Any ideas where I can buy some from?
What is it actually to fit over, 10mm sounds quite deep, I do a flexible "U" profile chrome plastic trim in lengths up to 15m which will go over anything up to around 3mm thickness, it's approx 8mm total depth. Don't know if that would do what you want?
10mm is the width or 8mm will do too. It's to go on side of car as trim, only needs to be 2mm or 3mm thick. Gonna visit some metal fabricators I think.
