Roughing up/keying GRP for repair
Avoneer - 8/9/05 at 10:25 PM
What's best for roughing up/keying the rough underside of GRP so that I can stick new matting to it?
Pat...
Hellfire - 8/9/05 at 10:43 PM
Very course grit - 80 then a quick wipe with meths to degrease. Use adequate precautions Pat... good ventilation etc etc
Avoneer - 8/9/05 at 11:06 PM
Thanks Mr Hellfie and for the cleaning tip on the other post.
Pat...
Triton - 9/9/05 at 07:00 AM
Pat........acetone will "kill" the wax in the resin so your next layer will bond ok....flap disc or like Mr Hellfire said mega gritty paper.
Are you having a go at repairing those wings then.....shame you are so far away as i could have done that for.
Avoneer - 9/9/05 at 11:08 AM
Cheers Mr Triton.
I fancy having a go as I have a full roll of matt and resins etc. left from my Avon.
I'll give you a shout when it all goes wrong though!
Still fancy the idea of making a mould and doing some in clear gel coat and wet lay carbon.
Pat...
jonbeedle - 9/9/05 at 01:39 PM
Hi, you have U2U.
Jon
Triton - 9/9/05 at 06:34 PM
Mr jonbeedle,
Where are you then?........repairing is the relatively easy bit.....spraying it is the work of someone that knows what they are doing........but i know really good lad who is a dab hand with the prep n spray bit and more than happy to do bits and bobs for "flash cash".. his words not mine.....he is not far from Newprt Pagnell if that helps any?
Pat,
eeee your neighbours are gonna luv you then when you start messing with the glass....
Mark
Avoneer - 9/9/05 at 07:29 PM
It's cool - got my dad to join in and I can do it as his house or boat yard!
No smells in my 'ouse!
Can you still by small pots of acetone from the chemist?
Pat...
mangogrooveworkshop - 9/9/05 at 08:13 PM
Pat...
the paint guys do acetone as well as any boots or lidls
Fred W B - 10/9/05 at 04:25 PM
I keep telling you guys - Carb cleaner is basically acetone in a spray can - very convinent
Fred WB
Avoneer - 10/9/05 at 08:34 PM
Oooooo - never thought of that!
That stuff even takes off the sticky labels from B&Q steel!
Pat...
lexi - 11/9/05 at 08:35 PM
In repairing glass boats I always use an old drill bit about 10mm. Fit in machine and use kind of parallel to surface to rough it up being careful not to go through. I like to expose some of the fibres as this helps when bonding. Soften with a little acetone before laying up. It`s important to prepare properly as polyester resin is not a good adhesive.
Alex
