i'm changing my MK grille to a black mesh jobbie any ideas on how to fix the mes in place?
bend the mesh over to form a lip and sikaflex it in place....won't move a bit
We did almost what Col says but we cut tabs into it as getting the mesh to lay flat on the back of the lip is almost impossible. With the edges of the
mesh being very sharp too you'll find it very ermmm frustrating and painful no doubt.
Get an 'almost' shape +1" then cut tabs into it bend these and use PU Adhesive (Sikaflex, tigerflex, Texflex) to secure. We put our
black mesh behind the MK Grille... enhancing the MK Grille.
HTH
I just PU'd some small wood blocks about half inch by 1 inch into the inside of the nose around the opening and then just fixed the black mesh by
screwing into them, simple & removable if required.
Rich.
