Anyone know of suppliers of these, preferably the friction type (so the deflector stays in the position you set) rather than the sidescreen lift-off type?
Any good???
http://cgi.ebay.co.uk/SIDE-SCREEN-DOOOR-
HINDGES_W0QQitemZ4604465822QQcategoryZ100921QQrdZ1QQcmdZViewItem
E-SCREEN-DOOR-HINDGES-STAINLESS-STEEL_W0QQitemZ4604467269QQcategoryZ100921QQrdZ1QQcmdZViewItem
Hi Andy
Even though these are much "sort" after, apparently
, I am really after the ones that hold their position. They are quite small and the
amount of movement on the centre pivot can be tightened/loosened using a small grub screw. I've seen them, just can't find a pictuire of
them or a supplier!
Brasscraft supply them @ £6.50 each
Brasscraft supply them @ £6.50 each![]()
Got mine from RS components - about 4 quid each (considerably less through work
go to http://www.rswww.com and search for hardware / hinges / plastic / adjustable
Marcus
