When to T cut
trikerneil - 2/6/06 at 07:11 PM
I've just sprayed some bits using cellulose.
How soon can I "Tcut" them?
I don't want to wipe all the paint off.
bilbo - 2/6/06 at 07:42 PM
IIRC you have to wait about 2 weeks for the paint to harden properly.
trikerneil - 2/6/06 at 08:01 PM
Cheers!
andyharding - 2/6/06 at 08:05 PM
I do it the next day. It's a lot easier while the paint is still soft!
Nick Skidmore - 2/6/06 at 08:49 PM
Don't use T-cut it's got lots of ammonia in and can lead to the paint going prematurely matt.
Auotglym do a paint restorer which is faster and better than t-cut with no ammonia. About £3.50 from Halfrauds.
Howlor - 2/6/06 at 09:00 PM
Use a Farecla rubbing compound. It is what the bodyshops use. I agree TCut can matt the paint and also change its colour with the ammonia. White goes yellow if you leave tcut on for 24 hrs!
Markp - 3/6/06 at 06:50 AM
I used t cut until I found the autoglym paint restorer. A lot easier to use than tcut and better results IMO.
Mark
TangoMan - 3/6/06 at 08:30 AM
It really depends on how much work the paint needs. If you need to remove dirt nibs and reduce orange peel than polishing by hand (with T-Cut or anything else) will be a long and tiring process.
T-Cut will be OK for just adding shine but anything else really needs doing with a polishing mop.
Either Farecla or 3M products will be suitable.
Fred W B - 6/6/06 at 06:01 AM
Years ago, when I was young and (maybe) stupid, I used Brasso to bring up a shine on a motorcycle tank I had painted. It seemed to work really well. Was this a bad idea?
Fred W B
