Ok wet and dry
What tools can you use?
What’s the best way to start?
What’s done first?
Dry sanding or wet sanding?
What’s the best sand paper for the job?
Is there one for carbon fibre only?
Thank matt
Originally posted by mat.price
Ok wet and dry
What’s done first?
Thank matt
Hi mat,
Please give some info on what you would like to do. If you are flatting off a good surface for painting you need far finer grades than if you are
repairing damage. For car bodywork most use wet and dry. A spot of soap in the water helps to lubricate it.
For final flatting before polishing ive used 1200 followed by 2000 grade.
What I’m planning to do is to take all the ruff edging of the carbon fibres body
What I don’t know is if this is the finished side? I.e. if I sand it down it will look the some as the rest?
Therefore what’s the best sand paper for the job high or low grade or special carbon sand paper?
Tools? I have asked some people about this and some sad to use a heavy-duty sander and blocks!
When starting what’s done first wet or dry and why? I know nothing about this other then the Avon book with lot of help? Not!
I’ve added this pic to try to show what I mean!
Your right I mean fibreglass!
40 or 80 grade is that using the aluminium oxide sand paper first then move on higher grade?
Sorry for the stupid questions I know nothing but this wet & dry thing
Thanks matt
If you go into any auto paint supplier and ask for 80 grit, they will give you exactly what you need.
You will also want some, 120,180 AND 240 grit to progressivley remove the scratches. Don't hope to bury them with primer as they will come back
through as the paint cures.
