Hi
My zorst pipe on my viento protrudes approx 30mm outside past the rear arch, will this be an SVA issue? it has a rolled edge.
cheers colin
This may count towards being the widest part of your car, from which light placements etc will be measured.
I cut mine back and re-welded the rolled end back on, so that it didn't stick out further than the arch
[Edited on 14/7/06 by JohnN]
It wasn't an issue on my test.
Mine sticks out about the same ammount.
ok cheers chaps, will leave it like it is n give it a go!
