Aluminium plate
iiyama - 13/12/06 at 07:07 PM
Wheres the best/cheapest place to get this from? Gonna fabricate a fuel tank so info on thickness would also be good! 2mm enough? Or should I got to 3mm?? Or more??
Ta!
Ian
pjavon - 13/12/06 at 07:16 PM
I would use 2mm, plenty strong enough. Don't know where you'd get it from at your end of the country as i live the other but it should cost you around £25-£30 for a sheet of 2.5M x 1.250M x 2mm ally.
If your a good welder i'd suggest 16 swg, will still be strong enough with the folds in it and the sheet should cost a little less as well
Paul
iiyama - 13/12/06 at 07:20 PM
Cheers mah man!
stevec - 13/12/06 at 07:29 PM
Try here maybe,
Steve,
Theres one in Southamton;
http://www.metalsupermarkets.co.uk/
[Edited on 13/12/06 by stevec]
907 - 13/12/06 at 07:40 PM
Hi Ian
I use Aalco in Norwich.
I think they have a depot in Southampton.
Without delivery and vat I've just payed £22.50 for 2m x 1m x 1.5mm (I get it through work)
or perhaps I should say my wife has just payed £67.50 for my Christmas prezzie. (Rear arches and bonnet in kit form )
hth
Paul G
1.5 would be plenty thick enough for a fuel tank
[Edited on 13/12/06 by 907]
iiyama - 13/12/06 at 08:11 PM
there is indeed an aalco just the other side of Soton from me. Ill check em out. Damned if Im gonna pay Dax 250+vat for a fuel tank!!!
pjavon - 13/12/06 at 10:43 PM
i get it from aalco in liverpool,didn't realise they were national
