so...how did you do yours?
having just bought an MK exhaust manifold and bolted it up i now need to cut the bonnet for clearance but really dont wanna ahem bugger it up
so whats the easiest way of doing this and getting it right?
cheers
james
I don't think there is any easy way to do it, just take your time , measure twice and alway cut less than you need, you can't put it back
but you can cut more.
I did mine piece by piece until I was happy with the fit.
I masked mine up with masking tape, measured up the positioning of the exhaust. Marked up the bonnet so the cut out was slightly smaller than i
needed cut that out, then cut it bit by bit till i was right. I cut it using my black and decker wizard and cutting disc.
Take your time and wear a mask...
It's the old Corn Flake box trick.
Clamp it to the chassis rail and hack away.
When your happy with the shape of the hole, use it as a template to mark the bonnet.
p.s. must be Kellogg's. You don't want any of that locost muck.
Paul G
as 907 says.
i do it to make holes in the RC planes.
1. fit your exhaust without the bonnet.
2. use a card template, clamped/taped to the chassis side.
3. cut the hole in the card board allowing a little clearance.
4. slit the card to allow removal of the exhaust.
5. remove exhaust
6. fit bonnet
7. use the cardboard as a template to mark the bonnet.
8. cut with confidence.
9. replace bonnet and check against your template.
note: the card is never removed from the chassis at all, not untill you are completey happy.
would like to add that this is how i intend to do mine...eventually..lol.
it aint rocket science.
it aint rocket science.![]()
Yup card template or you could have my old pinto bonnet, bit to far away though
