WHAT IS THE BEST WAY OF FINSHING THE ALI ...CAN I LACQUER(IS THAT HOW YOU SPELL IT) THE BARE ALI ?...OR DO I LEAVE IT BARE AND POLISH IT..MY PANELS ARE SHAPED AND NOT FITTED YET.IF I LAQUER THEM ILL HAVE TO DO IT NOW...WILL THE LACQUER CRACK AS THE ALI FLEXES DURING FITTING
Leave it bare and polish it occaisionally. Laquering could be prone to cracking, if not now, later on in the cars life. The pain of polishing will be
far less than trying to clean the laquer off......
HTH Stu.
P.s. No need to SHOUT dude
Totally agree with the above! Yes it is hard work, and currently testing products to see which one is easier- none so far, all bl**dy hard work, but
the end result is worth it.
ATB Fozzie
Farecla G3, should bring it up with virtually no effort
How about "bearding" on inside panels? Anyone ever had a problem with that?
Sometimes I think I'd like to paint the car to keep the maintenance simple. But then again, how many shiny ally cars do you see (esp. in the
USA)? Also, that shiny butt is the best crash protection I can think of!
Pete
thanks guys...
appreciate that..ill go with that...
glad to save a lot of wasted effort.......
what is....farecia g3...and wher can i get it...ive never heard of it....l
cheers again
colin
cheers buddy..
cant get a more precise and info filled answer than that..
unless...you had offered to polish it for me...haha
There's a product in the states called "Zoop Seal" that is made to keep polished aluminum from oxidizing.It's the bomb!You polish
the ali,clean the wax off with the cleaner supplied with the kit,mix the catalyst with the other bit(you must let it steep for 2hrs before
applying)and apply it with the little foam thingy they supply.
It then takes 8hrs to cure.
This sounds like a lot of work,but after you've polished a whole car it wont.
I've used this stuff on some aircraft and they absolutely stay shiny(its been four years for two of them!).
It holds up to fuels and so forth but it's one weakness seems to really caustic detergents.
You'll spend a day and $40 doing this but you wont have to fret over it again for a long, long time.
Good luck!
Fletch
thanks for that...ill look into it over here and see if i can trace it....
