hi i have used p40 on a whole but its not gone off it is hard but sticky is this ok as i have never used p40 before. i know i put enouth hardener in
it as its nice and pink.
(i was going to heat it with a heat gun to see if it helps it go off or will it be still a little tacky after 3 day)
if its gone pink you put too much hardener in it, should be white.
Yup. Should have gone off 2 and a half days ago
Put a thin skim of P38 over it and rub it down, it's not going to go anywhere
P40 should go off in about 20 mins and fully flattable in 30 mins
Originally posted by Peteff
Put a thin skim of P38 over it and rub it down, it's not going to go anywhere![]()
