i used a single pack of rivets for my stone guards, but some have corroded other are perfect..
any one else had a problem with a batch?
or do you think mine may be mixed,?
Gonna replace all now..sugestions..
Were they aluminium, stainless, or what?
If ally rivets in stainless they will corrode. Best to get steel or stainless rivets.
Caber
Monel is the answer to all the corrosion problems. Nothing will touch them.
see http://www.assda.asn.au/asp/index.asp?pgid=18533
for a description of the cause....
Originally posted by Hellfire
But dont use them when securing two metals, then the rest of the metal chassis/component suffers as it becomes the sacrificial cathode.
Replacing aluminium rivets is cheaper and helps protect whatever it is touching.
Does Zinc 186 have more zinc in it than Zinc 182 ?
If the stone guards are in the fibreglass rear wings how will the chassis become sacrificial?
Been 'the accepted norm' in yacht work for generations. Have a good look at masts and all sorts of other attachments on yachts, and they
operate in salt water.
Maybe the yacht fraternity have been doing things wrong for all these years? I don't think so.
If you've got corrosion problems, get some Zinc 186 paint, or a similar zinc rich alternative, and paint (dip)the rivets and holes as they go in.
It also helps seal things up, and stop the corrosion in the first place. Wipe off the excess after.
It also helps to use closed end rivets.
Syd.
Syd... we have no problems with corrosion - however just to point out the reason for Yacht's and things. Boats, Ships and yacht's (and other
things where dissimilar metals are joined by rivets and studs etc) have a large metal plate welded onto them (usually below water line or in the
water) which dissipates (re-routes) the electrolytic reaction between the Monel/Aluminium/Stainless Rivets and other dissimilar metals.
Therefore, they haven't been doing it wrong but realised the importance of this reaction and used the sacrificial plate method to protect the
rest of the Ship, Boat or Yacht. They also use this priciple on certain Hot Water Sytems where metals which are not similar, exist.
MORE INFORMATION
I know it isn't relevant to this instance - but as stated in my original sentence "when securing two metals"... ergo - if using rivets
to secure two dissimilar metals on a car - you may be reducing the corrosion resistance in another part/area of the car; maybe suspension parts which
are open to the elements etc...
Pete - as stated "when using two metals" obviously (unless he has metal arches) this is not relevant - hence the new paragraph.
Kindest Regards
[Edited on 3-10-07 by Hellfire]
