Scuttle
Simon - 26/11/03 at 10:32 AM
Peeps,
Does the top rearward edge of the scuttle count as internal or external for SVA - ie do I need a 19mm radius or 2.5mm radius.
Simon
Browser - 27/11/03 at 02:41 AM
Id've thought internal since a pedestrian is going to have to perform some serious aerial gymnastics to come into contact with it should you knock one over. Also, it is behind the theoretical 'windscreen' line. Anyone know for definite?
David Jenkins - 27/11/03 at 08:36 AM
I believe that the 19mm radius is only for the bottom of the dashboard, where your legs would collide in an accident. Everything else is to the normal internal min. radius (which I can't remember )
Simon - 28/11/03 at 09:48 AM
Cheers chaps.
Think I'll laminate the dash to the scuttle and radius the join - not excessively, but hopefully enough!!
Simon
