Hey up guys just about to do a deal on some Ali for me bodywork and dont have me book to hand. I was thinking of 1.2 mil half hard or does any one
have thoughts on this.
Any one who has done thier body how many 8 by 4 sheets will I need.
Bob
1.2 mm should be fine, half hard may be a little tricky to form around the boot area, but it has been used by other people with success.
3 sheets if you're not making a bonnet, 4 if you are.
Kingr
1.2mm should be right, I have used some 1.5mm and it can be a bit tricky to bend.
Nick
half hard is i think the 'std' alu term used for the correct stuff.
i think its also called 3003 grade.
If you get the wrong type, like david jenkins did, it will be a bas%^ard to bend regardless of thickness.
As I like to make life as hard as poss, I bought 2mm for my car.
Its EASY to bend.
You just need to use the soap and blow torch annealing method.
Use the search tool on my postings for soap and blow torch, and it will come up. Im not typing all that in again!
atb
steve
Thanks fellas, knowing my luck tho I'd better get 10 sheets as Im bound to balls up 6.
Bob
I emailed this to Baco in Leeds ....
Hi, I'm looking for some aluminium sheet and am of limited (read none) knowledge of aluminium.
I need to panel the sides of my car and make a bonnet from aluminium but
firstly need to source a low-cost supplier. Also I need to know what sort
of aluminium I need, I have an idea of what I need but need confirmation
before buying.
The only information I have on the type of aluminium I need is as follows
... 1.2mm (18swg) grade 3003 'half hard' ... I hope that makes some sense to
you as it makes little to me
Could you also let me know the cost of the aluminium?
And this is the reply I got ....
I think the aluminium sheet you are after is 3103 H14, (half hard).
We stock this at 1.2mm thick, sheet size 1805mm x 1350mm.
Price would be £35 a sheet, plus £13.50 carriage.
I've only had time to panel 1/2 of one side but it seems to be nice and easy to bend.
Guys,
I got a quote from Aalco (www.aalco.co.uk) for 5251-H22 of £24.78 per sheet for a 2500x1250x1.2mm sheet with Vinyl coating. This was based on an order
of three such sheets and I think this was pretty good.
Craig.
I used 16g half hard in 2mtrx1mtr sheets. They were not coated and cost about £18 each. I did bonnet, sides and back panel with 3 sheets. If I had
used it for the panel behind the seats I would have needed another one. I had enough off cut to do the tunnel top.
yours, Pete.
Righto then, I'll get it ordered today this guy quoted me £25 per sheet 8x4,so the price seems right.its a sheet metal place who put a call into
us that his phone system went down, so it looks like a deals, on we forget his bill he forgets ours,plus maybe a bit of guilotining and bending.
Bob
splitrivet,
Better make it a round dozen!
That way I can come and borrow some of the leftovers!
Terry
is the half-hard stuff now called 1050 H14? (looking to order some 1.2mm for rear tub & sides)
Back from the dead post new record??
If any....
This has to be....
This may help
http://www.aluminum.org/sites/default/files/TEAL_1_OL_2015.pdf
1050 is unalloyed aluminium... (see pages 7 and 33 (labeled 1 and 27 in PDF document)
Half hard is referred as the amount of hardening undergone trough forming.
You may revert this by annealing.
See: https://www.advent-rm.com/information/glossary.aspx?definition=tempers
HTH
If any....
This has to be....
This may help
HTH
Originally posted by craigdiver
Ah but I did do a search for the info before posting ;-)
[Edited on 11/2/18 by craigdiver]
If any....
This has to be....
This may help
HTH
Without me having to ‘revert this by annealing‘ (which sound like may add some time onto the job and not DIYable!) or going to metal university and learning what annealing and common aluminium alloy composition is, what am I asking for when I order the 1.2mm for my rear end & sides?
Thanks :-) (and thank you for your help, much appreciated)
Just to add another equation into the pot, when I built my locost in 1997-99, that does sound like a long time ago!
I went to my local metal supplier and ordered 1.2 mm sheets in 8x4 FEET (I like mixing up measurements
I was asked what type etc, and I just said medium, and that's what I got, it wasn't so soft it will dent with a finger pushing against it or
to hard to bend round the lamppost across the road
It works, no matter what it is,
steve
Hi, I'm going to laser cut the panels for my Fury rebuilding project. Is it necessary to use anodized alu panels? And going for commercial names: Peraluman or Anticorodal?
