Opinions please...
Now i need some tactics to complete it...
i was thinking, sanding.... glue, screws, filler and respary to black??? (want it yellow but will be difficult not??
Tks
[Edited on 23/6/08 by tks]
If you know the RAL code of your gelcoat, you should be able to get yellow paint to match your body....
its standard melon yellow..
but i hear that it never can match exactly..would it be visible..??
any tips on the filler / tricks needed to finish off....
do you like it??
Looks nice..
Getting an aerosol of the right yellow shouldnt' be that expensive, and if it doesn't look right, you could still spray it black...
only (constructive) criticism I would make is that they look like they're pointing down (forming an inverted "V"
but that could be a
trick of the camera.
yupsz.. thats well spotted...
the inner holes are 2,5mm higher... then the outer ones...
i'm thinking that i might put the brake and pos on the inner holes and the indicators and fog on the outer ones...
better???
anyway it was a difficult task with the fiat rear light clusters.....
That would probably help - I'm not sure the indicators would pass SVA in their current location.
Think the inverted "V" is emphasized by the lower edges of the arches, though - doubt it would be noticable if the lower edges were
level.
Nice work, though
The lenght of the complete cluster is 255mm...
the rule is 350mm so i hope they do..
Tks
Luego melon yellow is RAL 1028, i got a half litre can mixed up at the local paint suppliers for doing some of the donor bits to match my Melon yellow
bodywork, its a pretty spot on match and for a few pounds more, they will also mix up aerosol cans if you need them.
Im going to mix it to use in the compressor but thought afterwards that i should have got one aerosol made up from the batch just for those touch up
jobs..
I like the shape and think that yellow would be best?? It be v cool if you could use filler to blend them into your arches though might be difficult
to paint. Just a thought but maybe the indicators would look better on the outside??
Matt
I am planning to make up a mount similar to yours, but I am going to GRP it all togehter before spraying the whole lot. I like my lights, but they would stick through far too far into the wheel arch if surface mounted. Your solution looks very neat. Thumbs up from me!
thanxs!!!
today i also filled the back line up with more of the same shape...
it looks even better now...
will make some shots..when its a bit further to the end...
they look good
i always wondered if it would be possibile to get sum van lights persay and fit them to the main tub or is there not enough space because of fuel tank
or is it SVA?
