Which Black PU adhesive is the best?
Wurth or Tiger? (in black)
Can it be removed for replacing a screen etc or is it permanent!
Dave B
[Edited on 3/8/08 by Dave Bailey]
I don't know about Wurth sealer but we use Tiger sealer at work and it bloody good don't get it on your hands
Can you get the joint apart if you need to?
You can cut along a seam of PU with a [very] strong knife. I wouldn't use one with a thin blade because of the risk of it snapping but a sturdy knife would do it. PU is like a hard rubber when set.
Unless you are going to fit a hood I wouldn't bother,the rubber sealing strip would be OK. The first time you get caught in the rain you will see why.
I do not have the rubber seal so was planning to seal with the PU because the profile of the bottom of the screen does not match exactly the scuttle.
I take it that with no roof you mean you will get wet so a leaking screen is not important!
Dave B
Used black silicon from Wickes on my aero screen!
