I have fixed the glass in the frame of my windscreen using a rubber seal in the same way that I did for my last build, a Robin Hood 2B. (ie main
section of U section upside down, flat rubber trim on top, push the glass in. Repeat with the botton of U section. Trim rubber with stanley knife.)
This time however, the glass moves about in the frame. I could gum the whole lot up with sealer but that seems a little heath robinson.
Any views on the best way forward?
thicker i.e. tighter rubber? May be better to get proper U profile rubber rather than flat?
Woolies do some which might work.
Or is the frame a little too big?
[Edited on 28.08.2008 by Humbug]
i have used these guys
baines
Try Seals + Direct
