johncarman
| posted on 22/12/09 at 08:25 PM |
Water based paint
There have been a number of discussions on here about which type of paint to use, one which is often recommended as being safe and easy for home use
is water based. I have in the past sprayed my car with Cellulose with few problems, but now I want to respray and I am wondering if I should be
considering water based ??
My main question is what primer and what clear coat to use with these, there are lots of mentions of using 2K clear but surely this defeats the object
of using water based for safety reasons ?? I would be greatful if somebody could point me in the direction of primer and clear which can be used with
water based and are safe for home use.
Thanks,
John
blue2cv
| posted on 22/12/09 at 08:40 PM |
i think you'll find that the only clearcoats available are 1k and 2k and yes it does make a mockery of the whole goody two shoes water based
thing, we use 1k or 2k primer, water based colour then lacquer of either type depending on what we are doing,
blakep82
| posted on 22/12/09 at 08:46 PM |
doesn't water based mean it will just run off if it gets wet?
i think water based is still very expensive too isn't it?
________________________
boggle
| posted on 22/12/09 at 09:24 PM |
i get water based for £50 a litre and solvent based for £55 a litre...
you need lots of warm air and a dry area to paint it, and then 2k laquer to finish it... octoral ms 2:1 with a fast hardener and 10% thinners works
best i have found...
you may find that if you dont want mettalic then a good 2k commercial paint is best....
u2u me for details
boggle
| posted on 22/12/09 at 09:26 PM |
also its the solvent in the base coat that is said to cause enviromental issues and not the cyanide content in the lacquer...
u2u me for details
Steve G
| posted on 22/12/09 at 10:20 PM |
Of a greater concern to me personally is the potential health issues if proper protective equipment isn't used with 2K.
There's plenty of info on Isocyanates if you do a search on Google etc but basically it can cause various respiratory diseases such as asthma.
Given that its generally through longer term exposure but is it really worth the risk for home use if there's an alternative?? Doubt your
neighbours would be too impressed if you were playing in the garage with a Cyanide derivative either!!
I've used 1K laquer myself as advised by my local paint supplier for home use. Go find a reputable local paint supplier (ensures proper
compatability with everything you use that way) and take their advice on what to use given the facilities you have and the finish you want.
