aaron-wxm
| posted on 10/1/11 at 03:25 PM |
brackets
hi all ive baught myself a caterham replica
need to start making brackets for cycle guards, headlights and all others
could some1 show me some pics of theres or links to guides please
thanks in advance
femster87
| posted on 10/1/11 at 03:37 PM |
hi mate, do you know what uprights you've got? cortina's or sierra. if they are sierra's I know GBS stock them with insert mushrooms
already welded on. and not too expensive i think
James
| posted on 10/1/11 at 04:31 PM |
What actual car is it though?
You said before "based on plans he bought". So it's a Locost? Based on the Ron Champion book? Or a Roadster by Chris Gibbs? A Tiger
Avon?
They're all very different beasts when it comes down to it.
James
- Muhammad Ali
aaron-wxm
| posted on 10/1/11 at 08:44 PM |
right i start again...
... im new to kit cars and i will be asking alot of questions
what are uprights?
i think (find out tmoro for sure) its a caterham replica and i think he used the ron champion book does that sound about right?
thanks
aaron-wxm
| posted on 10/1/11 at 09:27 PM |
also im going to make my own pannels
alli or steel better? & which size thickness?
thanks
James
| posted on 15/1/11 at 01:32 PM |
If it's based on the orginal Ron Champion book then it's a Locost.
You'll have a much easier time of it when posting if you stick to calling it that!
The uprights are the big chunk of cast metal that the wishbones attach to. They hold the hub to which the wheel bolts!
If your car has been kept to standard Champion plans then your uprights will be from a Cortina.
However, a lot of people used the similar Sierra upright as it is/was cheaper.
Hope that helps!
James
- Muhammad Ali
James
| posted on 15/1/11 at 01:33 PM |
thanks
Like in so many cases, it depends what you're doing with them.
But it's probably best to say use ali. I used 1.2mm stuff.
HTH,
James
- Muhammad Ali
brookie
| posted on 15/1/11 at 05:45 PM |
could help if u put your location as well m8 people near u could come and help u out
