Yorkie
| posted on 11/5/11 at 12:52 PM |
Centre Mirror and Aeroscreen
I'm having difficulty deciding how to mount the centre mirror.
My two options are: Mount the mirror to the scuttle and pass the stem through a hole in the aeroscreen or mount the mirror directly to the
aeroscreen.
Not sure if the aeroscreen is strong enough when bolted in place.
How have you mounted yours?
40inches
| posted on 11/5/11 at 12:57 PM |
I used the first option and used a grommet to seal around the mirror stem
afj
| posted on 11/5/11 at 01:02 PM |
option one here
eerrrrrrrrrrrrrrrr
Humbug
| posted on 11/5/11 at 01:03 PM |
Th thread here shows a pic of how I mounted mine: solid mounted to the scuttle
though the screen with a spacer, so the screen is sandwiched between the top and the spacer. It made it very stable and also helped reduce flex of the
aeroscreen.
big_wasa
| posted on 11/5/11 at 01:35 PM |
The first one.
couch22k
| posted on 11/5/11 at 02:48 PM |
Option 1 on the scuttle mine.
adithorp
| posted on 11/5/11 at 03:47 PM |
I spoke to someone at Stoneleigh with option 2. I t was being altered to Op1 as Op2 vibrated so much the mirror was useless.
http://jpsc.org.uk/forum/
Yorkie
| posted on 11/5/11 at 03:50 PM |
Thanks guys.
Option 1 it is then.
