Author: Subject: Wheel offset question
joemotion
posted on 24/5/11 at 08:21 PM Reply With Quote
I currently have 17's on my Avon running Sierra discs all round. code on wheel states e 38 which I assume is offset. seen a potential set off 15's with the code e 35. will these fit?
tomgregory2000
posted on 24/5/11 at 08:24 PM Reply With Quote
yes its only 3mm difference
Daddylonglegs
posted on 24/5/11 at 08:50 PM Reply With Quote
Someone will correct me if I'm wrong, but I think it means they will stick out a tiny bit more that's all
mcerd1
posted on 24/5/11 at 09:14 PM Reply With Quote
as above they will stick out 3mm more
but don't worry about it - most sierra's were either ET38 or ET35 anyway
(my XR4x4 was ET35)
[Edited on 24/5/2011 by mcerd1]
loggyboy
posted on 24/5/11 at 09:34 PM Reply With Quote
They might not stick out more, most 17s are 7 inch wide, where as most 15s are 6 inch wide, so they will be 25mm narrower, 15mm of that will be lost on the inside, and 10mm would be lost on the outside.
joemotion
posted on 25/5/11 at 05:16 AM Reply With Quote
Cheers guys I'm looking at 15 x 7's with a 35 offset in lieu of my 17 x 7's 38 offset. looking at the comments above this se ems to be OK.
