midlifecrisis
| posted on 22/7/04 at 08:41 PM |
REAR WHEEL ARCHES
Hi All Youre probably going to shoot me for this ,but... why is it all the locosts I see (including the one I've just purchased)Have such out
of proportion wheel arches ,to the size of wheel?They are either toowide and/or too large a diameter . the fronts fill the mudguard reasonable,with
the locost f/glass items,but could look better I feel ,with tighter fitting guards ,the rear ones are all over the place!
Jon Ison
| posted on 22/7/04 at 09:00 PM |
like this you mean ??
NS Dev
| posted on 22/7/04 at 09:10 PM |
Personally I don't think they are all too bad, some are worse than others but then you get what you pay for, they aren't low cost for no
reason! If you want really high quality then there is a suitable proprietary manufacturer, but not cheap!
Jon Ison
| posted on 22/7/04 at 09:14 PM |
there are the odd dodgy ones about, but most are fine.................. i spent ages making sure everything was bang in the middle n square, and the
arch was full.
Hellfire
| posted on 23/7/04 at 11:36 AM |
Also, don't forget that the front wings travel up and down with the wheel, whereas the rear wings are fixed and need some of the additional
space for the rear wheel suspension travel. Also, the gap won't be as visible with someone sat in it
DaveFJ
| posted on 23/7/04 at 11:50 AM |
I think maybe you've been looking at too many chav cars ?
yes they put huge wheels on which fill the arches but because they have full bodywork there is space inside the wheelarch for the wheel to move up
into, by the very nature of a Locost's rear arches their is very little room for movement therefore you must have a gap......
Aside from that, as has been mentioned on here many times... bigger wheels and rubber band tyres actually make the car much harder to handle and very
unpredictable.
Dave
midlifecrisis
| posted on 23/7/04 at 09:23 PM |
Thanks all for your wisdom! I am going to build some rear arches in steel using a cut and added to trailer type arch . Fronts will be trailer guards
fitted tight to the wheels . Maybe shapes /quality of f/glass arches have improved over the years,and I have got early,strange shaped ones (oo err!)
