MEERKAT
| posted on 1/7/11 at 08:34 PM |
Aeroscreen / Windscreen
Hi can anyone let me know if I fit an aeroscreen to my Mk Indy will it leave visible holes if I later want to fit a proper windscreen?
Cheers Chris
"To alcohol, the cause and solution to all of life's problems"
- Homer J Simpson
whitestu
| posted on 1/7/11 at 09:03 PM |
Depends on the type of aeroscreen.
I had a Mac1 polycarbonate aeroscreen on that bolted through the upright bit on the scuttle and now have a Caterham full screen. None of the holes
from the aeroscreen are visible.
Stu
MEERKAT
| posted on 1/7/11 at 09:17 PM |
Cheers Stu I think I will have to look at one or two other cars to see how to fix the aeroscreen but thanks for the advice.
- Homer J Simpson
Davegtst
| posted on 1/7/11 at 10:44 PM |
All mine is held on by is the 2 bolts on either end for the mirrors. If i wanted a proper screen later i would still have the mirrors in the same
place and no extra holes.
stantman67
| posted on 6/7/11 at 04:11 PM |
Did the windscreen to aero conversion on a Westy and found there were visible holes (not helped by original poor fitting by original builder. I used a
carbon mods aero, fitted well but wouldn't cover all the holes. Most guys in Westy club who run both make up a quick release alternative
scuttle. Not sure of the fixing points for an MK aero and screen!
