ad0_5
| posted on 30/7/11 at 05:58 PM |
IVA fail - wing mirrors
Hi all. My first post, having gleened mucho helpful advice from archive topics during the build of our MK Indy (many thanks to all!)
We had our IVA test at Beverley a couple of weeks ago and it was a pretty good experience. We went expecting to fail on a few things, but really
wanting to pick the inspectors brains and get a 'work to' list so that we can finish the car off and get it on the road before the decent
weather disappears this year!
Anyway we had a 'good fail' (if there is such a thing).
Should also say that the Beverley inspector we got was very reasonable, did much less on the external radius checks that we were expecting (v.
relieved about this, especially after what MK had told us about some of the panels being wrong for the 'new' test).
No pics at the moment as the car is back at the 'rents. Will try and get some soon though.
Basically the things that were wrong were:
Fuel tank - needed straps and earthing - now sorted
Front indicators - too far inboard - now extended with a bit of a copper tube bodge
No interior rear view mirror - picked up an iva ok one from CBS
Rear fog lamp not squarely facing the rear - sorted
Exhaust support bracket needed cover trim on edges - done
Wiring to rear lamps needed grommets through the bodywork - now done
A bit of wiring to tidy up under the dash - done
Internal panel needed under dash on passenger side to deflect passenger away from chassis bar that runs across the car - panel made, but not yet
fitted
VIN plate on wrong side of car and needed 'MK Sportscars' stamping in it - now sorted
Brake fluid sticker missing from near brake reservoir - done
Side repeaters not visible from full required angles - they were fitted to the scuttle and I've tried various solutions and
read loads on peoples experience with this. After trying wing mirrors with LEDs in (that only seem to face forwards so are useless!) I've
resigned to fitting some to the front cycle wings. I still don't like this solution, but its better that the rear wings imo and I've got
some nice small led ones, so they don't stick out too bad.
So, really the only thing that I think we still need to sort is the wing mirrors before it's retest time, but here I'm struggling!
The ones I had fitted were fairly cheap ones (from MK themselves I think!) that had glass in them that was so distorted the inspector couldn't
make out anything behind him at all!
I've had 3 different sets now and not found any that have really been suitable.
Have tried E-Tech F1 mirrors (with rubbish LEDs in - not bright enough), that fitted well and looked good but weren't really suitable for IVA
(sharp edges on front with not much to stick rubber covers to and I think the glass wasn't tall enough), but I might go back to these when my
pair for the test fall off (without the LEDs)!
Also tried an ebay buy that had a bend in the stalk at totally the wrong place and have spent a full day today going round motorbike shops and salvage
yards looking for R1 or GSXR mirrors without much luck!
Has anyone got any advice what to try next?
How have people who've used motorbike mirrors in the past got them to fit? The angles on the brackets/stalks of all the ones I've looked
at have been wrong for mounting the mirrors on my scuttle (no full roll cage) and the ball joint doesn't seem to have enough movement to
compensate. Have you had to make adapter brackets to get them to fit?
Any thoughts/advice or steers towards something suitable would be much appreciated.
jrrsparky
| posted on 30/7/11 at 06:24 PM |
kitpartsdirect ltd "new design wing mirrors IVA Ok e4 marked"
fitted these to my MK indy ready for IVA, they seem ok but only time will tel
big_wasa
| posted on 30/7/11 at 06:53 PM |
Any pics ^^ The e-tec style give the best view of any ive tried but there is that edge.
stevegough
| posted on 30/7/11 at 08:24 PM |
I went through IVA with the e- tech F1s on - good rear visibility, nice angle adjustment, I just filed the sharp edge all the way round, and he was
happy with this, but you can always superglue some rubber trim on to be sure. By the way, there were also my 3rd set of mirrors - I also tried one set
where the cranked - angle was useless no matter what you did with it.
The other point I will pick you up on is that your side repeaters may fail on the front wings - best to put them on the front of the rear wings (they
need to be within 2400mm of the front of the car. (I believe I have heard of someone passing with them on the front wings, though)
The best of british for your retest, and a very warm welcome to the forum, good luck!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
ad0_5
| posted on 30/7/11 at 08:55 PM |
Cheers guys. Think I'll get the F1's without the LED's and try and find some suitable trim to fit on.
I did check with the inspector about the side repeaters and he actually suggested the front cycle wings and confirmed that they only test them in the
straight ahead position. I guess there's a fair bit of room for interpretation by the inspectors on this element!
ad0_5
| posted on 31/7/11 at 08:57 AM |
stevegough - is there any chance could you just check the height of the reflective surface on the F1's for me please?
I was thinking it needed to have a 76mm height when I measured them, but have just re-read that section of the manual and it's only 70mm.
40inches
| posted on 31/7/11 at 03:04 PM |
I put rubber trim on my F1 centre mirror using
THIS tip (page
298)
stevegough
| posted on 31/7/11 at 07:07 PM |
just got in from work - will check and get back to you.
Luego Locost C20XE.
big_wasa
| posted on 31/7/11 at 07:36 PM |
Its 70mm long from iva v10 that I am working to. I beter check if there is a newer one.
They are well over that.
My third set and by far the best view of all of them.
[Edited on 31/7/11 by big_wasa]
stevegough
| posted on 31/7/11 at 07:54 PM |
I have just measured mine - by the looks of it, they are identical to Warren's (Big Wasa) - the max height of the 'reflective
surface' is 66mm which surprisingly actually falls just a touch short of the 70mm requirement ! They are 143mm wide.
The tester made no reference to this, but definitely commented that the rear view afforded by my mirrors was 'extremely good'.
Luego Locost C20XE.
ad0_5
| posted on 31/7/11 at 10:39 PM |
It was the 70mm height that I was concerned about, although I agree the rear view was really good with the ones I had.
Now I have the dilemma of whether to fit something I know he could fail me on but hope he isn't too concerned about or to carry on looking for
something else.......
.....think I'll just fit the F1's with some suitable trim glued on the edge and hope the field of view is good enough to satisfy him -
I've already got the mounting holes for these anyway from the LED set I had.
Thanks for your help all, I'll let you know how we get on.
stevegough
| posted on 1/8/11 at 04:43 AM |
Your call, but I think you'll be alright with these. Many have used them for their test.
Luego Locost C20XE.
rdodger
| posted on 29/1/13 at 09:30 AM |
I thinking of using these and wondered if any one had don IVA with them recently. It looks like to the letter of the law they shouldn't pass
due to the mirror height?
loggyboy
| posted on 29/1/13 at 09:57 AM |
The Etech ones? acording to this:
linky they measure 80mm, which is
10mm more than the 70mm required.
[Edited on 29-1-13 by loggyboy]
Mistral Motorsport
rdodger
| posted on 29/1/13 at 01:18 PM |
Hi Thats what I thought (80mm) but everyone else quotes them 68 to 70mm.
loggyboy
| posted on 29/1/13 at 01:35 PM |
Has the design changed? a call to europa might be prudent.
Mistral Motorsport
