carlknight1982
| posted on 22/4/13 at 07:48 PM |
Fitting stone guard set
I've had a look about and ordered a set of argon fibre stone guards from kit parts direct
What's the best procedure to fit them, rivets or bonding them on?
Logic will get you from a A to B
Imagination will take you everywhere.
SPYDER
| posted on 22/4/13 at 08:02 PM |
"Argon Fibre" you say. I bet they're light!
austin man
I would bond them personaly, they should be flexible enough you will need to tape them on while the Seal sets. PS are you sure theyre argon and not
carbon lol
carlknight1982
| posted on 22/4/13 at 08:13 PM |
Damn iphone autocorrect lol
What would you use to bond them?
J222jra
| posted on 22/4/13 at 08:15 PM |
Bond them on using tiger seal.
Davegtst
| posted on 22/4/13 at 08:26 PM |
Are they any good? I was looking at a set but they seemed too cheap to be decent. I would probably put them on with double sided tape. If you tiger
seal them on you will never get them off again if you needed to.
carlknight1982
| posted on 22/4/13 at 08:29 PM |
Ill let you know when they arrive tomorow
carlknight1982
| posted on 23/4/13 at 06:24 PM |
A little thin but should do the job
rb968
| posted on 23/4/13 at 06:36 PM |
I have them on mine. Trimmed the edges a bit.
As you said, bit thin but look ok. I riveted them on with black small rivets.
Rich
carlknight1982
| posted on 23/4/13 at 07:20 PM |
I've never worked carbon what do I cut it with to get a nice edge
rb968
| posted on 23/4/13 at 07:56 PM |
Tbh it's so thin I cut mine easily with a big pair of sharp scissors. No problem.
