deeceee09
| posted on 21/10/13 at 05:01 PM |
Rivnut problems
Does anyone have any bright ideas on how to extract screws from Rivnuts that have come loose? No easy access of course as an ali panel obscures the
fixing.
Treachery and old age will always triumph over youthful enthusiasm.
yellowcab
| posted on 21/10/13 at 05:10 PM |
Story of my life - its a bugger.
Awaiting ground breaking replies also...
loggyboy
| posted on 21/10/13 at 05:19 PM |
Ally or steel rivnut?
Mistral Motorsport
40inches
| posted on 21/10/13 at 05:22 PM |
If you can get a lever under the edge of the panel, put pressure under the head of the screw while unscrewing. If that doesn't work drilling, or
chiselling off the screw head.
I fell out with rivnuts years ago, I no longer use ally ones, they spall on the thread and lock the screw in, only use steel or stainless, but self
tappers, or a thread tapped into the chassis tube has never let me down yet.
[Edited on 21-10-13 by 40inches]
deeceee09
| posted on 21/10/13 at 05:40 PM |
Thanks guys. I'll get back to it in the morning. They are steel Rivnuts into MS tube with SS screws. Did try the levering from behind idea
but that access not too great either.
40inches
| posted on 21/10/13 at 05:46 PM |
That's a real b*gger, I hate rivnuts with a vengeance, you can have twenty holding a panel, but it only takes one that spins to ruin your day
yellowcab
| posted on 21/10/13 at 05:48 PM |
Brilliant! Best
quote of the year so far.
austin man
| posted on 21/10/13 at 06:38 PM |
try tightening it first with a bit of speed ie an air ratchet or impact gun, this sometimes tightens the rivnut back into to panel
bi22le
| posted on 21/10/13 at 07:08 PM |
I have solved this in the past in two ways.
1) If it has 8mm bolt then use a ratchet to pull the bolt off at an angle before undoing it. This may allow additional grip as its gripping the to and
bottom of the plate to prevent turning.
2) Depending on head use a suitable sized open ended spanner or pliers to pull the head away. If this dont work then as suggested, screw it in tight
to try and re grip the rivnut.
I think these may have been mentioned but thought I would state in my own words.
Please read my ring story:
Bare
| posted on 21/10/13 at 08:01 PM |
It may be possible to wick in a wee bit of Ca (crazy glue) into the bit of the rivnut that fixes into the panel it's supposed to clamp
permanently on.
Oil the threads first! cuz if you bungle it and glue the screw threads then you will need to grind the Rivnuts' mounting flange (and still
stuck in there screwhead)...Off.. to remove the rascal.
Irony
| posted on 21/10/13 at 08:10 PM |
If its a rivnut with a big flange try gripping with small molgrips.
Its happened to me a few times but I still feel they are better than Satan's very own fixings - self tappers.
snakebelly
| posted on 21/10/13 at 08:24 PM |
Try not to use rivnuts anymore for this reason but if i do then i smear the exterior with PU adhesive first and always always grease bolts or set
screws before fitting them. Bit late i know but thought i would share.
Not Anumber
| posted on 22/10/13 at 12:11 PM |
I need to buy a few rivnuts. What type are less prone to failing/ spinning.
deeceee09
| posted on 22/10/13 at 12:37 PM |
OK ground the wretched things off in the end
adithorp
| posted on 22/10/13 at 12:41 PM |
Steel, plated and splined. Drill the hole size so the rivnut is a tight fit before riveting.
http://jpsc.org.uk/forum/
David Jenkins
| posted on 22/10/13 at 03:38 PM |
On occasions I have put a tiny weld on 2 or 3 places round the rim of the rivnut, then tidied it up with the angry grinder to give a flush top (needs
a gentle touch!).
Of course, this is a bit of 'bolting the stable door when the horse has bolted' when you're trying to get a screw out of a spinning
rivnut, as described in the OP!
