Dale
| posted on 9/7/14 at 12:53 PM |
Rust on back of bonnet /pinhole
Good morning
For legality reasons (in Canada) I am using a fair bit of original body panels on my build. I am using the original bonnet,scuttlewith vin plate, and
boot although all are not quite in the shape they started in. This keeps me on the grey side of being what you call a ringer, and allows me to keep
it registered as a 72 mgb.
What I have after stripping down the bonnet is rust under the reinforcement areas that when sideways under bonnet. I have just used the angry
grinder so far on it and would sand blast it but I am afraid of warping the hood. I think it will be too thin to mig the pin holes ( I will likely
find at least one more.) Would a metal based filler work to fill in from the back side and would it stick with the under hood temps of a turbo
engine. Is there an etching solution to get down to the bare metal better than the wire twist wheel before doing so.
Dale
[Edited on 9/7/14 by Dale]
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
stevebubs
| posted on 9/7/14 at 02:37 PM |
for small holes like that, I'd be tempted to braze some metal in...
Dale
| posted on 10/7/14 at 01:12 AM |
I may try putting some brass in there but I really dont want to warp it either.
Dale
sebastiaan
| posted on 10/7/14 at 09:57 AM |
You could try and get some silicon bronze mig wire? Have a look on google.
mark chandler
| posted on 10/7/14 at 10:26 AM |
Have you thought about soft solder, if it gets hot enough to melt this then your paint will be bubbling up by then!
As it's a pin hole just clean, flux put a bobble of solder on top and flash the plumbing torch at it, minimal/zero distortion if you are quick
and have a narrow flame.
Mr Whippy
| posted on 10/7/14 at 11:53 AM |
seriously though... how could they ever tell it was the original donor steel used in the panel?! your even painting it
Dale
| posted on 10/7/14 at 12:51 PM |
I am documenting it with pictures. I have shots from when I first started and started on the body work of the mgb. The local motor vehicle office
was show pics when I asked about registration and there were no problems as long as it was pre 1980 but could not be registered as a historic vehicle
because of the modifications.
Dale
Dale
