Slimy38
| posted on 24/6/25 at 01:50 PM |
Painting underneath of the bonnet
Hopefully a nice simple one, I want to give the underside of my bonnet a once-over with some black paint. It's either roller or brush because of
the rough surface, and as you might expect I'm not aiming for a showroom finish. Any recommendations on type of paint and/or where to get it
from?
jacko
| posted on 24/6/25 at 02:34 PM |
Yes fire proof paint is my recommendation say like you paint chimneys with if you have to paint it
555
| posted on 24/6/25 at 02:45 PM |
I can't make any recommendations, but jacko's fireproof seems one pretty reasonable.
Out of curiosity, why are you wanting to paint the underside of the bonnet?
Slimy38
| posted on 24/6/25 at 03:03 PM |
There's a few reasons. First, I quite like the look of it when I see other cars open at kit car shows and the bonnet is painted. The second is
where I've attached my wheel arches, the fibreglass and metal are different colours to the base bonnet so it's just to blend them
altogether;
The last one is that the bonnet is very slightly transparent in certain areas. It's just the thickness of the build-up (or lack thereof) but it
makes things look patchy, again when it's open.
Slimy38
| posted on 24/6/25 at 03:12 PM |
Sounds quite reasonable, I'll give it a go. Thanks.
| posted on 24/6/25 at 03:14 PM |
Understood and thanks for explaining.
My MK Indy bonnet didn't had 4 bonnet catches rivetted to it. Aside from that the layup was thick enough all over.
mcerd1
| posted on 25/6/25 at 12:15 PM |
Painting the rear side of GRP is always a good idea - it helps stop any rough/loose fibers from ending up in your hands
Years ago someone recommended just using a decent household exterior gloss paint, its worked great on other parts of mine (as a bonus you can
sometimes get discount paint if it's in a colour that no-one if ever likely to paint a house)
but something a bit more heat resistant sounds like a good idea for the engine bay
bi22le
| posted on 25/6/25 at 02:33 PM |
I dont know what paint is used to paint the underside of my bonnet black but I do know that now it is painted black you cant see the dirt!
This is good BUT under the bonnet does get dirty, the end result is when you are not careful you get covered in grime by just rubbing slightly against
it (like I did and ended up looking like I had climbed up an exhaust pipe!).
Please read my ring story:
Slimy38
| posted on 27/6/25 at 02:52 PM |
That's an interesting thought. I have a post-IVA task to fill in the arches of my car (full body rather than a seven) but if you're saying a
seven still gets muck under the bonnet perhaps I should just accept it as inevitable and remember to hose things down more often?
