JohnFol
| posted on 11/12/02 at 12:28 PM |
Rivets and rust
ok, you spend ages getting your chassis prep'd and painted to prevent rust. Then you drill 500 holes in it and insert rivets.
What stops the water from going through the rivet into the tubing?
If there is nothing, how do you prevent it rusting internally?
philgregson
| posted on 11/12/02 at 12:36 PM |
Option one: Use blind rivets and plenty of sealant.
Option two: Have you considered gluing the panels on? - see 'Bondage' lower down this section.
Phil
JohnFol
| posted on 11/12/02 at 01:35 PM |
Saw the 'bondage' bit and have posted quite a few comments. The outcome of that was you still need some rivets somewhere to stop the glued pannels
moving around.
Not come across blind rivets. Will do the research, but don't all rivets end up with a hole through the middle?
geoff shep
| posted on 11/12/02 at 05:01 PM |
Jon Fol, read about these on a bloke's locost website and searched - found this:
Sealed end rivets
JohnFol
| posted on 11/12/02 at 05:06 PM |
I know you're really hiding an inner passion to be a guru on washer and fastener technology .
Seriously, many thanks!
wicket
| posted on 11/12/02 at 06:17 PM |
I'm using both dome & c'sk head blind rivets. They are readly available from good fastener suppliers like Namric (the Nut & Bolt Store) in Brighton;
RS also stock dome headed ones.
Viper
| posted on 12/12/02 at 10:29 PM |
How about don't drive it in the rain
Deckman001
| posted on 12/12/02 at 10:46 PM |
I can just imagine the clarke of the cource postponing a race due to 'Rain'
