Rorty
| posted on 17/12/02 at 02:43 AM |
Custom fit seats.
I realise there are quite a few different makes of seats available for the rather confined space of the average Locost, however, if anyone is
interested in a truly custom fit seat, I could perhaps help.
I'm 6'7" tall, and find all the aftermarket seats are not ergonomically suited to me, so I now make all my own seats (see Photos>Rorty>Custom alloy
seat. But please note, the ones I make now have a lot of lightening holes).
They are made from 2mm aluminium sheet, similar to the American off-road , and speedway seats, and have removeable padding/cover (good idea for an
open top Locost too). They are both light and rigid.
I would be happy to draw up the seat pattern to suit any individual's dimensions. It's important that the seat fits perfectly, to hold you securely
for fast cornering, and for comfort.
The patterns are on a 1" square grid (see Photos>Rorty>Seat pattern), which is then transfered onto the aluminium sheet. The blank is then cut out
with a jigsaw/laser, folded, and welded. Any car/marine upholsterer can then make a cover in your chosen material and colour.
I normally include the pattern as part of a set of plans for an off-road buggy, but I would be happy to do them for people on this list in exchange
for say, a UK car mag etc.
Obviously these seats won't be for everyone, as most people will prefer to buy ready made seats. Also, not everybody has access to a folding press,
or someone who can weld alloy.
However, if you're tall, or you have limited space for a conventional seat, contact me off forum, and I'll do what I can to help.
[Edited on 17/12/02 by Rorty]
Cheers, Rorty.
"Faster than a speeding Pullet".
PLEASE DON'T U2U ME IF YOU WANT A QUICK RESPONSE. TRY EMAILING ME INSTEAD!
Findlay234
| posted on 20/12/02 at 08:58 AM |
hi rorty, i contacted you through email about a set of these seats.
just wondering if anyone else knows if there is a prob with these seats and sva??
David Jenkins
| posted on 20/12/02 at 09:21 AM |
If they are strong, firmly mounted and have all sharp edges covered to the correct radius of padding, then there's no reason why they shouldn't pass
SVA.
The only other thing would be to ensure that the holes for the seatbelts are really smooth and unlikely to wear the belt material.
Rorty
| posted on 21/12/02 at 01:59 AM |
I usually tack weld an AL "U" channel around the whole seat, but also recommend that others glue some of that rubber "U" channel in place as an
alternative.
Similarly for the belt slots, I normally cut pieces of the same rubber slightly too long, glue the ends together with Superglue, and force them into
the slots.
If the upholstery is to remain afixed to the seat, I think Dreamin' Thieves or Eurospares or someone sells the snap-together belt slot trims. You
would just need to adjust the patern to accomodate the exact shape of the plastic trims.
Cheers, Rorty.
David Jenkins
| posted on 7/1/03 at 12:29 PM |
Rorty,
What info do you need to make a design?
cheers,
Rorty
| posted on 8/1/03 at 02:27 AM |
David, just a few simple measurements. Get someone handy to help, otherwise a wife would do.
Sit on the floor, against the wall. Stand a set square or book on the floor, and place it against your hip (widest part), move to other side and
repeat. Measure the distance between the square/book marks.
Measure from the floor to the sleeve seam on your shoulder. Only measure across your shoulders (seam to seam) if you're built like the Incredible
Hulk.
Push your arse against the wall, and measure from the wall to 2/3 thigh.
That's it.
Cheers, Rorty.
parksy
| posted on 14/2/03 at 09:41 PM |
seat design
HI RORTY
JUST CLOCKED YOUR DESIGN IF I SEND YOU THE INFO CAN YOU DESIGN A SEAT FOR ME? LET ME KNOW ME YOUR PRICE(BE GENTLE).
CHEERS JON
Rorty
| posted on 15/2/03 at 02:59 AM |
Parksy, That's fine, just email me your measurements (oooh-er missus!), and when it's done, I'll sting you for a magazine subscription....I think
my CCC one has run out.
Cheers, Rorty.
parksy
| posted on 15/2/03 at 01:42 PM |
Rorty
hips= 40 cm, wall to 2/3 thigh =44 cm, floor to shoulder seam = 58 cm. Am I deformed? or this is what you want price sounds good but what is
ccc?
see you soon
parksy
robinbastd
| posted on 15/2/03 at 10:22 PM |
CCC used to be a magazine about tuning and improving cars. Now it is about track days and making your Peugeot go faster. A bit like MaxPower without
the tits. Bought March issue,and am giving it to the 2 year old to draw in- that way at least someone will get something out of it
Nice to see you back Rorty,hope all is well
Rorty
| posted on 16/2/03 at 12:25 AM |
Parksy, I'll make a start on your seat in the next day or so, and get back to you.
Robinbastd, OK, you've put me off CCC. It was indeed an excellent all-round mag at one time. What's good at the moment? Anything?
Thanks, it's good to be back.
Ooops! I forgot to ask, what is the maximum width you can accomodate in the seat area of your particular car?
[Edited on 16/2/03 by Rorty]
Cheers, Rorty.
chrisg
| posted on 16/2/03 at 10:57 AM |
Welcome back Bruce, hows tricks?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
parksy
| posted on 16/2/03 at 02:06 PM |
custom seats
lo rorty
glad to see all your old contacts gettin back to you, you been away?, anyway max width for seat is about 42 cm. Lookin at the dimensions I gave you
this means i have a fat arse???
Rorty
| posted on 16/2/03 at 11:58 PM |
Chrisg:
I'm well, thanks for asking. Just glad to be back in front of my puter again!
Parksy:
max width for seat is about 42 cm. Lookin at the dimensions I gave you this means i have a fat arse?
Yes. I'll get back to you shortly.
Cheers, Rorty.
Rorty
| posted on 20/2/03 at 02:08 AM |
Parksy, the seat pattern is done. I could email it to you, though unless you have a CAD program, and can accept .dxf files, it would be best if I mail
it to you.
Would you email me please?
rorty@iprimus.com.au
Cheers, Rorty.
MK9R
| posted on 20/2/03 at 08:26 AM |
How heavy are one of these seat?
Rorty
| posted on 21/2/03 at 02:58 AM |
MK9R:
Depending on individual size, but usually 4-5kgs.
Cheers, Rorty.
auzziejim
| posted on 23/2/03 at 05:22 AM |
Custom seats
Are these seats OK for short arses? i ask because I am 5'9" and my dad is 5'8". as we wil be the only people to drive the car (when its done) i
will need a seat (seats) that will fit. I am asking as a thought for the future really as I am only at the 'clean all the donor parts stage'
James
Rorty
| posted on 24/2/03 at 02:46 AM |
auzziejim:
Yup, they can be made any size you want (within the narrow limits of the average Sevenesque Locost).
I also have drawings of the rally type of side-mount aluminium seat brackets, which can raise the seat up/forward/backwards, with just a couple of
screws.
BTW Parksy, I didn't offer you the side-mounts, as I thought you'd be mounting the seat directly onto the car's floor/chassis. Let me know if you
want them too M8.
Cheers, Rorty.
PHULL
| posted on 4/3/03 at 02:00 PM |
mags
well I found that CCC was going down hill as well
Zoom has always been a great mag
would u accept a slab?
carnut
| posted on 4/3/03 at 04:33 PM |
regarding the weight.
You say they weigh 4-5 Kg
Does anyone know how much a fibreglass seat such as used by MK in the indy weighs for comparison?
Rorty
| posted on 5/3/03 at 12:40 AM |
PHULL:
I've given up the demon drink . but Mrs. Rorty would be happy with a dozen
Stollies!
Email me with your dimensions as per above, so I can get Mrs. Rorty pi$$ed.
carnut:
Not sure, probably less, best speak to PTM, or the Horse's Mouth.
Cheers, Rorty.
MK9R
| posted on 19/3/03 at 01:21 PM |
Bringing this back from the death
A mate who has just replaced his fibre glass seat with custom ali seats says it makes so much difference being weld ridged in the car rather than the
seats bending around, he says you can feel what the back end is doing perfectly.
Rorty, i would really like a pair of these, if i send you the dimensions can you do me some. I may want 2 slightly different ones as two of us are
sharing the car, so we could have a seat taylored to ourselves and make them easily swappable.
Just let me know what you want for them.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Viper
| posted on 19/3/03 at 07:46 PM |
"regarding the weight.
Does anyone know how much a fibreglass seat such as used by MK in the indy weighs for comparison?"
The seats i have put up for sale weigh in at 4.25 kilos each, and used a 8x4 sheet for the pair, my Carbon/Glass seats weigh 3 kilos.. any help?
Rorty
| posted on 20/3/03 at 01:01 AM |
MK9R:
Rorty, i would really like a pair of these, if i send you the dimensions can you do me some. Just let me know what you want for them.
MK9R and I have been emailing each other about the seat patterns, but for everyone else's benefit, I usually acept a book or magazine
subscription in exchange for customising the seat pattern. Amazon are pretty good at taking your money on-line, and shipping world wide.
Cheers, Rorty.
