Avoneer
| posted on 8/9/05 at 10:25 PM |
Roughing up/keying GRP for repair
What's best for roughing up/keying the rough underside of GRP so that I can stick new matting to it?
Pat...
Hellfire
| posted on 8/9/05 at 10:43 PM |
Very course grit - 80 then a quick wipe with meths to degrease. Use adequate precautions Pat... good ventilation etc etc
Avoneer
| posted on 8/9/05 at 11:06 PM |
Thanks Mr Hellfie and for the cleaning tip on the other post.
Pat...
Triton
| posted on 9/9/05 at 07:00 AM |
Pat........acetone will "kill" the wax in the resin so your next layer will bond ok....flap disc or like Mr Hellfire said mega gritty
paper.
Are you having a go at repairing those wings then.....shame you are so far away as i could have done that for.
Avoneer
| posted on 9/9/05 at 11:08 AM |
Cheers Mr Triton.
I fancy having a go as I have a full roll of matt and resins etc. left from my Avon.
I'll give you a shout when it all goes wrong though!
Still fancy the idea of making a mould and doing some in clear gel coat and wet lay carbon.
Pat...
jonbeedle
| posted on 9/9/05 at 01:39 PM |
Hi, you have U2U.
Jon
paper.
"Everyone is entitled to an opinion however stupid!"
Triton
| posted on 9/9/05 at 06:34 PM |
Mr jonbeedle,
Where are you then?........repairing is the relatively easy bit.....spraying it is the work of someone that knows what they are doing........but i
know really good lad who is a dab hand with the prep n spray bit and more than happy to do bits and bobs for "flash cash".. his words not
mine.....he is not far from Newprt Pagnell if that helps any?
Pat,
eeee your neighbours are gonna luv you then when you start messing with the glass....
Mark
Avoneer
| posted on 9/9/05 at 07:29 PM |
It's cool - got my dad to join in and I can do it as his house or boat yard!
No smells in my 'ouse!
Can you still by small pots of acetone from the chemist?
Pat...
mangogrooveworkshop
| posted on 9/9/05 at 08:13 PM |
Pat...
the paint guys do acetone as well as any boots or lidls
Fred W B
| posted on 10/9/05 at 04:25 PM |
I keep telling you guys - Carb cleaner is basically acetone in a spray can - very convinent
Fred WB
Avoneer
| posted on 10/9/05 at 08:34 PM |
Oooooo - never thought of that!
That stuff even takes off the sticky labels from B&Q steel!
Pat...
lexi
| posted on 11/9/05 at 08:35 PM |
In repairing glass boats I always use an old drill bit about 10mm. Fit in machine and use kind of parallel to surface to rough it up being careful not
to go through. I like to expose some of the fibres as this helps when bonding. Soften with a little acetone before laying up. It`s important to
prepare properly as polyester resin is not a good adhesive.
Alex
