macspeedy
posted on 21/1/03 at 09:25 PM |
Dashboard edges
The SVA manual states that the radius on the bottom edge of a dashboard has to be of 19mm what have other people done, pics if poss, Thanks in
advance.
CairB
| posted on 21/1/03 at 09:39 PM |
I used some edging strip on the edge of the ally dash with 3mm foam rubber then vinyl over the top. The SVA manual allows a 5mm radius if covered with
a non rigid material with a hardness of less than 50 shore A.
Photo in photos - Cairb - Mad dash.
It attracted the attention of a few of the testers at SVA.
philgregson
| posted on 21/1/03 at 11:09 PM |
Not done it yet but plan is to make flat dash of ali sheet with bottom edge bent under to appropriate radius and edging strip over top of turn over in
case that offends them.
Obviously no photo but can post drawing if I've not made it clear.
Phil.
Ian Pearson
| posted on 22/1/03 at 09:26 PM |
Hi Mac,
I made my dash out of MDF. To form the 19mm radius on the lower edge, I glued some thick card to the front lower edge, and then using some wooden
dowel of the right diameter, I folded the card around the wood and glued it to the rear side of the dash. Once this had dried, I fibreglassed the
entire dash, and have since covered it with foam, and vinyl. If you e-mail me, I'll send you some pics.
HTH,
Regards, Ian.
[Edited on 22/1/03 by Ian Pearson]
chrisg
| posted on 22/1/03 at 10:42 PM |
And this is how I did mine:
Dash
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
MB
| posted on 26/1/03 at 10:00 AM |
I've made my dash out of exterior grade plywood and the bottom edge has been padded with pipe instulation. The pipe insulation was modified my
cutting out 90degrees and the remaining 270degree section was staple gunned in position. The whole dash was then covered in thin foam and the top
layer was leather lookalike PVC material.
Bob da builder
| posted on 27/1/03 at 12:51 PM |
I made my dash out of 1/4 plywood and machined a hockystick section out of timber and mitered the corner angles and screwed it onto the ply dash. the
hockystick section is a D section with a rebated face in the shape of a hockystick!difficult to explain but if you go to a joinery workshop they will
know what you mean.!! soz not got any photos!
Happy building
p.s. remember if you use a hard dash the instrument bezzels must have a radius of 3.2mm for the SVA!
