Author: Subject: Paint for inside of GRP panels?
chrsgrain
posted on 6/2/06 at 12:14 PM Reply With Quote
Hi all,
Am planning on painting the inside of the paels, as the GRP is vary variable in thickness, and so looks different colours - was going to paint it black so it all looks the same - but has anyone got any bright ideas about which sort of paint would be good?? Want to brush or roll on to avoid any overspray problems
Chris
nitram38
posted on 6/2/06 at 12:59 PM Reply With Quote
When I made my own panels, I put the same pigment into the resin as I did with the gelcoat. This meant the panel is the same colour all of the way through.
DaveFJ
posted on 6/2/06 at 01:07 PM Reply With Quote
I would of thought some rubberised underseal typr paint would be ideal.....
Dave
RazMan
posted on 6/2/06 at 01:24 PM Reply With Quote
Painting the inside is usually done for cosmetic reasons but it also stops light penetrating, therefore changing the colour.
Ideally, a flowcoat in a dark colour should be applied by the GRP supplier. Failing that, any thick paint should do it. I've used Smoothrite in the past to good effect.
Raz
ned
posted on 6/2/06 at 01:34 PM Reply With Quote
I think I have a similar issue on one side of my scuttle, do you have to use a similar colour paint on the inside? Would a dark colour not look like a shadow if the gelcoat was a bit thin?
cheers,
Ned.
beware, I've got yellow skin
RazMan
posted on 6/2/06 at 01:39 PM Reply With Quote
Ned, if your GRP is that translucent it would be better to apply the same colour first then finish with black.
Raz
ned
posted on 6/2/06 at 02:32 PM Reply With Quote
yup, it is a bit translucent, put my hand behind the scuttle and noticed the gelcoat change colour with the shadow.
Of course I won't say which manufacturers grp it is, they seem to be having enough problems without me naming and shaming them!
Ned.
