miserableoldgit
| posted on 9/11/06 at 11:43 PM |
Sticky foam tape
I'm trying to source some black "Nitrile like" foam about 50mm wide by 5mm thick to stick on top of the body sides and nosecone as
an insulator between these and an aluminium bonnet.
Has anybody got any ideas of where I could get something like this?
Youth and vitality are wasted on the young
RazMan
| posted on 9/11/06 at 11:46 PM |
I found something similar in B&Q - 50mm black sponge tape which I used as fuel tank strap padding.
Raz
miserableoldgit
| posted on 9/11/06 at 11:54 PM |
Sticky Foam Tape
B&Q? That well known Locost supplier; never thought of them!
Was it fairly dense or like Aero?
givemethebighammer
| posted on 9/11/06 at 11:55 PM |
foam Rubber strip
http://www.vehicle-wiring-products.co.uk/VWPweb2000/fasteners-2/fasteners-2.html
RazMan
| posted on 10/11/06 at 12:02 AM |
Closed cell but I would class it as medium density - worked for my fuel tanks though.
Raz
chockymonster
| posted on 10/11/06 at 12:50 AM |
There are probably cheaper places but I got mine from this guy
http://stores.ebay.co.uk/all-and-sundry
dave r
| posted on 10/11/06 at 06:29 AM |
woolies
ordering some stuff this week
zetec7
| posted on 10/11/06 at 07:12 AM |
If you have any scuba-dive supply shops in your area, they use very nice closed-cell neoprene for wet suits, and often have strips of scrap...
http://www.freewebs.com/zetec7/
Danozeman
| posted on 10/11/06 at 08:16 AM |
I got mine from woolies trim having searched for months to find some locally with no success.
Dan
| posted on 10/11/06 at 08:21 AM |
woollies - they do lots of this in various thickness 3 mm, 6 mm in 25 mm width and then wider and thicker stuff.
the 3 mm, 25 mm should do ya.
paulf
| posted on 10/11/06 at 09:45 AM |
I used some Armaflex tape i found at work. It is used for lagging refrigeration pipes etc and is closed cell neoprene. If you have a local industrial
refrigeration company it may be worth trying them. They also use it in sheet form about 20mm thick , this is ideal for padding seats etc.
Paul.
miserableoldgit
| posted on 10/11/06 at 01:38 PM |
Sticky Foam Stuff
Thanks all, plenty of choice there for me to go for. Woolies is an unusual one, will most certainly investigate that one. Coming from the Black
Country we are about as far away from the coast as it is possible to be in this country, and our waterways only come up to your waist, so Scuba Diving
shops are a bit thin on the ground - but like the thinking, that type of material would be ideal. Might make a bid for Steve Irwins wet suit on Ebay,
only one hole in it and shouldn't be a problem.
DarrenW
| posted on 10/11/06 at 10:12 PM |
Mac#1. They are the one stop shop for all LSIS bits.
