TimC
| posted on 14/3/07 at 12:51 PM |
Preparing Ali for Powdercoating
I have a number of brackets etc made from anything up to 3mm Ali plate. How well do I need to prepare the cut edges for powdercoating?
I'm unsure whether or not to spend ages making them nice if:
a. The powdercoat will work better with a keyed surface, or
b. If the powdercoat will cover small imperfections anyway.
TC
dan__wright
| posted on 14/3/07 at 01:03 PM |
are they not being plasted before they are poweder coated? think thats the norm.
Moorron
| posted on 14/3/07 at 01:04 PM |
Hi boss,
Stuff we have done for work sometimes gets scratched during handling here, so we use a scotch bright pad on an angle grinder to clean it up, this
comes back fine from the powder coaters.
Also we have things punched so it leaved a very small sharp edge (.25mm???) and this also comes back fine.
i wouldnt bother polishing anything up.
Sorry about my spelling, im an engineer and only work in numbers.
jambojeef
| posted on 14/3/07 at 01:05 PM |
Although the powdercoat is quite thick comapred to a spray paint - it still picks up imperfections quite noticeably if the finish I get from my local
powdercaoters is anything to go by.
I would clean it up so you cant see saw marks but dont worry about the sort of scratches you might get from very coarse wet and dry paper / ally oxide
paper or from draw filing - they shouldnt be noticeable
TimC
| posted on 14/3/07 at 01:30 PM |
Thanks all
In particular the CBR Turbo Twins... I want a go when its done!
Moorron
| posted on 14/3/07 at 01:34 PM |
quote: Originally posted by TimC
Thanks all
NO!
JB
| posted on 17/3/07 at 08:00 AM |
I would expect a nice radiused edge or corner to be better for adhesion than a sharp edge. Also with a sharp edge there is more risk of the coating
getting chipped off.
When I had my aluminium parts powder coated they went through a chemical wash / etch before hand. I am not sure of the exact process. Peatys at
Bradford did all my stuff.
