Author: Subject: Clearance between top of tire and rear wing.
Dale
posted on 23/3/07 at 06:19 PM Reply With Quote
I am just about to build up a mold if not for better words for my rear wings. How much clearance for the top of the tire to the wing is normal. I would think that about 3 inches should be close as the minimum amount before the tire can hit anything -or the bump stop-
Also when a tire spins (excessivly) like when watching a dragster take off the tire grows a fair bit. I am assuming that it grows to the center and the sidewalls have to stay the same so it should not make that much of a difference.
Its a road car with live axle.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
Chippy
posted on 23/3/07 at 11:21 PM Reply With Quote
Easiest way to make sure. Remove the springs from your suspension units, refit bare units, and allow the car to settle onto the bump stops. Allow say 25mm on top of that, and you will be OK. Very unlikely that you will ever hit the bump stops, but the unlikely sometimes happens. HTH Ray
Simon
posted on 24/3/07 at 12:45 AM Reply With Quote
Dale,
Have you got unequal length w/bones on you car. If so, keep the tyre slightly inside the arch at rest, and it will automated increase camber and come inside arch more with tighter arc scribed by (upper) wishbone.
I've never managed to spot an expanding tyre. Not unless it's got about 5psi in it, and doing 300mph
Are mine close enough for you
Simon
C10CoryM
posted on 24/3/07 at 02:21 AM Reply With Quote
You want 1" between the tire and anything else when on the bump stops. This goes for the sides too. This is assuming you are running a reasonable sidewall.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
Dale
posted on 24/3/07 at 02:38 PM Reply With Quote
Thanks, Going to the local hot rod show today to get some idea on the rear.
Dale
Dale
