Author: Subject: Fiberglass Oz. & SQ Yard
j2eDX
posted on 26/3/07 at 03:16 AM Reply With Quote
What weigh and sq. yard and layers would I need to cover aprox 70"x150" car? What type of fiberglass would you recommend? mat or cloth or both?
[Edited on 26/3/07 by j2eDX]
Fred W B
posted on 26/3/07 at 05:32 AM Reply With Quote
Hi
Some discussion HERE
Fred W B
twybrow
posted on 26/3/07 at 07:25 AM Reply With Quote
Quite a vague question, but here goes anyhow:
GRP is not particularly stiff in thin sections, as such, the shape of your part will oftern give your panel stiffness. therefore for small/curved/flanged panels, you will be able to use 2 x 450gsm layers of chopped strand glass. For larger/flatter panels, you will need soemthing to add a little thickness. I would suggest 3mm 'Coremat' This is purely used to build thickness (and stifness) to flimsy thin panels. You could use a woven material (cloth) but again, without thickness it is unlikely to be stiff enough for your purpose. If you have a mroe specific question, let me know.
trextr7monkey
posted on 26/3/07 at 08:18 AM Reply With Quote
I personally have no idea but here's a manwho will definitely be able to guide.
http://www.ecfibreglasssupplies.co.uk/store/
as usual nowt to do with me except a staisfied customer
