Author: Subject: Rivnuts in fibre glass?
iiyama
posted on 25/2/08 at 02:27 PM Reply With Quote
Want to bolt the rear arches on, can I use rivnuts in fibreglass? Are there special types or just use the normal version? Do I need to re-inforce the area with say some aluminium?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
rayward
posted on 25/2/08 at 02:28 PM Reply With Quote
i put some repair washers behind rivnuts into fibreglass, but a couple still have small cracks around them
hth
Ray
worX
posted on 25/2/08 at 02:30 PM Reply With Quote
I'd perhaps rivnut my own FG (with a washer in support) but not someone else's!
This is what I did on Tim's MNR (the rivnut is only in the ali and the ali is riveted to the body - all behinf the lip of the arches, naturally!):
iiyama
posted on 25/2/08 at 02:34 PM Reply With Quote
they countersunk rivets? Or does the wing piping hold the arch clear of the rivet head?
worX
posted on 25/2/08 at 02:52 PM Reply With Quote
The rivets are not countersunk, I just chose to buy a couple hundred of a few different sorts last time I bought some FROM HERE and the type I used were incredibly slim-headed! (and so, yes, the piping more than takes up the imposition!)
The rivet's serve virtually no purpose when the arch is attached...
twybrow
posted on 25/2/08 at 04:30 PM Reply With Quote
What you need are Big Heads
I used these in loads of places (structural and non-structural) when I worked at Sunseeker and they are amazing little fasteners. Combine with Sikaflex and they wont ever budge!
Johneturbo
posted on 25/2/08 at 04:59 PM Reply With Quote
I used jacknuts, got the idea from someone else on here. they are perfect for the job
HERE
[Edited on 25/2/08 by Johneturbo]
RazMan
posted on 25/2/08 at 05:01 PM Reply With Quote
Bigheads are designed for the job. Give them a call and blag some samples - they are very helpful. in fact I got enough 'samples' to do most of the jobs on my car
Raz
Johneturbo
posted on 25/2/08 at 05:20 PM Reply With Quote
the good thing with the jacknuts is you dont need access to both sides, ie if you've already fitting the inner panels.
iiyama
posted on 26/2/08 at 08:18 PM Reply With Quote
Thanks guys.
Ill use Worx's idea as I have a load of ally rivnuts!
MikeRJ
posted on 27/2/08 at 10:33 AM Reply With Quote
HERE
Look like cavity wall fixings!
Schrodinger
posted on 27/2/08 at 09:50 PM Reply With Quote
HERE
They are similar but shorter the ones I used were called hollow door fixings.
Keith
Aviemore
