2ltwin
| posted on 3/12/03 at 06:23 PM |
Nosecone??
Hi
Have recently bought a rolling chassis which has been built 6 inches wider than the book, is there a nosecone out there that will fit or will
modifications be needed??
Many thanx
dblissett
| posted on 3/12/03 at 08:36 PM |
you will need to check the front top section
because standard nose cones are 24" and robin hood do a 26" one
the chasis might be 6" wider but it might have a standard 24" front end
good luck dave blissett
2ltwin
| posted on 3/12/03 at 08:55 PM |
Front top section measures 30 1/2 inches accross at the widest point
| posted on 3/12/03 at 11:22 PM |
probably stuffed for a prefab one then. It is possible to buy one and cut it in two, and put a section in to widen it. Maybe hard to get smooth
though.
Simon
| posted on 4/12/03 at 11:50 AM |
2ltwin,
The Viento IIRC is 6" wider than book, so that may be a good starting point!
Simon
James
| posted on 4/12/03 at 12:23 PM |
As Simon said, the only pre-made one I'm aware of is for the Luego's Viento.
I've no idea how tall it is though. Contact ChrisW about it as he's the only person I know building a Viento.
HTH,
James
2ltwin
posted on 4/12/03 at 07:32 PM |
Cheers for all the advice, phoned luego but wont sell the nosecone seperate. sha me but Ill probably have to butcher one!
Simon
| posted on 5/12/03 at 10:29 AM |
2ltwin
see the nosecone pics in my archive - added 4" to standard nosecone
Simon
| posted on 5/12/03 at 01:35 PM |
nice! roughly how wide were your front top and bottom bars? about 28 and 17?
just realised mine may actually be similar to the book anyway. time to measure.
thanks!!
[Edited on 5/12/03 by JoelP]
