PHULL
posted on 27/10/08 at 02:35 AM |
How to curve 1600X500 sheet lengthways
Hi there
I wam building a Monopin inspired single seat hillclimb special. powered by a honda vtr1000. my main hurdel at the moment is figuring out how I could
bend a curve with a 186mm radius into a 1600 long by 500 long sheet of 1.2mm aluminium.
any advide would be great
maartenromijn
| posted on 27/10/08 at 08:01 AM |
As per the book? If I remember correctly, they put a pipe (around 100mm diameter) on two stands, and just bend the ali around it.
I can think of numerous variations on this method. Around a fence-pole for example.
You can make a model to check if you have the correct radius.
BLOG: http://thunderroad-super7.blogspot.com/
John Bonnett
| posted on 27/10/08 at 09:24 AM |
Good Morning, I think maartenromijn is absolutely right with his method if you don't have access to slip bending rolls. You can make a T dolly
using steel tube of the correct diameter and tap the aluminium round using a wooden slapper or flipper evenly a bit at a time along its length.
You have not mentioned what grade of aluminium you are planning to use but I would suggest pure aluminium our grade 1050A being the easiest to form.
I'd be very interested to see some pictures as you progress with the project.
atb
John
Humbug
| posted on 27/10/08 at 09:32 AM |
If you don't have bending tools, round a telegraph pole or something similar using ratchet straps should get you close
PHULL
| posted on 27/10/08 at 09:10 PM |
cheers fellas
might try the power pole idea, being 1600 long it is
the progress is very slow, but I could post a few photos later
austin man
| posted on 27/10/08 at 11:01 PM |
when I made my bonnet for my locost I created two wooden templates and formed the sheet around them this does allow you to peen the ends over giving
some additional rigidity.
prior to doing thi I rooled the front edge by follding it over a 1 meter alluminium ruler giving a double skin this also helped the rigidity
