Bob C
| posted on 2/3/04 at 12:17 PM |
golden locost...?
Who saw "salvage squad" on the box last night - model T racer with polished brass bodywork. It's a look that could work on a
locost... is it allowed? how much heavier than ally? Anybody made one?
cheers
Bob
Staple balls
| posted on 2/3/04 at 12:21 PM |
i can't see why it wouldn't be allowed, but i get the feeling it might be quite heavy
flak monkey
| posted on 2/3/04 at 12:32 PM |
Like Staple Balls says no reason why it wouldnt be allowed...but
The density of brass is about 8400kg/m^3 (heavier than steel!) compared to ali which is 2700kg/m^3
So your brass bodywork will weigh a nice 3 times as much as your ali bodywork!! I worked out youd have about 15 kg of ali in a normal chassis....or
45kg!!  of brass...
Would look cool....
[Edited on 2/3/04 by flak monkey]
Sera
http://www.motosera.com
Staple balls
| posted on 2/3/04 at 12:36 PM |
having never played with brass i'm not sure. but would it be an option to use thinner sheet, like 0.8mm instead of 1.2mm? that'd drop
quite a bit of weight
flak monkey
| posted on 2/3/04 at 12:39 PM |
With 0.8mm it would still weigh twice as much as ali youd have to go down to 1/3 thickness...ie 0.4mm to keep the same weight as ali. And that may
be a tad flimsy (But brass is about 1.5 times stiffer than ali....)
Sera
A Badger
| posted on 2/3/04 at 12:41 PM |
Robin Hood are supplying their cars using Stainless coated with Titanium or some such exotic material. The resultant panels are gold and shiney.
I guess it ends up being a little heavier that Alu, but looks good in the pcitures.
Andrew
Staple balls
yeah, i realise that, but it'd be better than 45kilos, then would it be sturdy enough thinner like that?
Bob C
ouch that is heavy... I'll have to tot it up for sides bonnet & boot, with black wings & nose...hmmm
Is there an issue with fatigue resistance/ cracking? Ugh - keeping it clean, doubt many lacquers are up to automotive spec..
I guess I'l just paint ally after all - sigh...
cheers
Bob
Staple balls
| posted on 2/3/04 at 12:42 PM |
Andrew
one of my first thoughts was if anodised alu was an option, but i'm not sure you'd get the right look
flak monkey
| posted on 2/3/04 at 12:45 PM |
Brass is 1.5 times stiffer than ali. But without sitting and doing a load of maths i dunno if it the strength of the brass would be comparable to the
ali.
Also brass is a bit more brittle than ali (correct me if i am wrong :p) So it will crack easier when you bend it (work hardens faster iirc) which also
means it would be more prone to fatigue.....
Sera
| posted on 2/3/04 at 01:19 PM |
I saw it at a show last year - somehow it just looked cheap and nasty (or was that the car underneath ). It wasn't gold or brassy in colour
- not very attractive IMHO.
| posted on 2/3/04 at 01:30 PM |
...and don't forget that brass is VERY expensive in large sheets, especially when it's polished with protective sheets stuck on, as they
used.
rgds,
P.S. I wouldn't have driven that car at anything above walking speed around Brooklands! Or with that wonky wheel, either!
Surrey Dave
| posted on 2/3/04 at 03:53 PM |
Anodised Ali
When I built mine the ali sheet supplier was Alcan (Edenbridge) they could supply anodised sheet in all sorts of colours ,(gold .red ,blue) but I
thought it might look grim if it got scratched.................
theconrodkid
| posted on 2/3/04 at 03:56 PM |
spot the delidarate mistake?unique car with unique steel wheels,mr model t had a spare pair under the bench?nice looking when it was done tho
who cares who wins
pass the pork pies
Kitlooney1000
| posted on 2/3/04 at 08:15 PM |
is this the gold car you are on about
