Charlie_Zetec
| posted on 29/9/09 at 02:38 PM |
Rear panel light mounting
It occured to me the other day that the issue around IVA and protection of the fuel tank has lead me to not add a spare wheel carrier to the back
panel, but instead carry a can of tyre weld. I've got no problems with this, and understand the consequences.
But what have you all done about mounting the rear lights? Where I've screwed mine in place the tips of the screw protruse inside the
fibreglass to the extent that I really should cover them up. But is this call for some silicone sealant or similar smeared over the ends, or do I be
a bit posh and ask someone with a lathe to turn me down a piece of plastic bar bored out and screw it over the excess? I just don't fancy
something small and pointy digging in to my fuel tank/rear tyres in the event of an impact (I understand if that happens, this is probably the least
of my worries!).
Thoughts on a postcard, please....
(or replies here may be quicker!)
[Edited on 29/9/09 by Charlie_Zetec]
| posted on 29/9/09 at 02:49 PM |
Use bolts with dome head nuts on the inside of the panel?
Screw a bit of wood on the protruding screw?
Our of interest, which lights and where have you got them?
Mine are on the rear arches except the fog light and number plate light whichare to the right and above the fuel tank anyway.
blakep82
| posted on 29/9/09 at 03:08 PM |
as nick says, bolts and dome head nuts.
i wouldn't just screw lights into fibreglass either. would think they'd pull off a bit easily
________________________
jacko
| posted on 29/9/09 at 08:19 PM |
Do your light fit within the 400mm from the widest part of the car ?
