Author: Subject: Bonnet scoop
madrallysport
posted on 19/7/10 at 10:12 AM Reply With Quote
Bonnet scoop
Guys I'm after a bonnet scoop, my engine fits under the bonnet but is tight and doesnt allow for a air filter, i dont want to cut a hole and leave the filters showing so i'm going to fit a scoop. I seen one of the carbon moods site (carbonmods scoop) buts too wide for me, I'm after something similar but about 400mm wide and 450mm long, dimensions have a bit of come and go in them.
Were have you guys bought your scoops from as i've seen some nice ones fitted to cars on here over the last few years.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
GeoffT
posted on 19/7/10 at 11:07 AM Reply With Quote
I've just bought one from an L200, something like this
Probably near(ish) to your required dims, I can get you the exact size if you want.
madrallysport
posted on 19/7/10 at 11:10 AM Reply With Quote
I like that a lot, what width is it Geoff
GeoffT
posted on 19/7/10 at 11:13 AM Reply With Quote
I'm going up to my garage later today, I'll put a tape measure over it and get back to you.
I know at least one other person has used one, so they may beat me to it......
GeoffT
posted on 19/7/10 at 12:36 PM Reply With Quote
It's 490mm long but only 310mm wide, so maybe a bit narrow for your purposes?
Pretty much flat on the underside, there's some ribs under here that you may have to fettle slightly.
About 55mm at it's deepest point but as it's a teardrop shape considerably less toward the edges.
Fits with 6 small captured bolts on the underside. Fortunately mine didn't have 'Animal' plastered all over it...
HTH, Geoff.
madrallysport
posted on 19/7/10 at 03:04 PM Reply With Quote
Magic, i think it looks great, going to have a punt on it, as i said my dimensions are there or ther abouts so it should let me away.
Many thanks for all your help.
