Leg
| posted on 6/3/12 at 10:22 PM |
Wheels help
Hi everyone.
I'm looking for a second set of wheels (for track tyres) for my MK Indy R. It runs 15x6.5 ET 38 pcd 108 4 bolt wheels. I'm after
lightweight black ones.
I was going to buy some rota slipstreams but I can't get any in that size (or even 15x7 with the st of the specifications the same) for love nor
money.
I was hope someone on here might have some ideas please?
Rich
[Edited on 6/3/12 by Leg]
daniel mason
| posted on 6/3/12 at 10:33 PM |
rotas wont be cheap! you looked at compomotive cxr's? team dynamics pro-race.? orr the anthracite caterham ones?
also iould fit 13" wheels for track use,but thats just my opinion
Leg
| posted on 6/3/12 at 10:35 PM |
They are only around £430 a set.
Maybe I should go for smaller wheels and get more rubber. Would I justgo for the same offset and width but get tyres with a larger sidewall so the
overall size was the same?
daniel mason
| posted on 6/3/12 at 10:41 PM |
a 195/50/15 has a nearly identical rolling radius as a 205/60/13. obviously the 13"s will be way lighter too.
take a look in my blog,i run the caterham r500 13" wheels on my mnr. you may like the style.
Leg
| posted on 6/3/12 at 10:43 PM |
Thanks. Do you think they will be ok fitting in my cycle wings? The 195/50/15 just fit now.
mark chandler
| posted on 6/3/12 at 10:48 PM |
As you want these for track days then get 13" wheels and second hand slicks, you will love the grip and tyres are £15 a pop and will last
surprisingly well.
Regards Mark
tomgregory2000
| posted on 7/3/12 at 07:04 AM |
just make sure the 13" rims will clear your brakes
Leg
| posted on 7/3/12 at 07:42 AM |
Very good point. I've got reasonably large will woods on there. Thanks.
Leg
| posted on 7/3/12 at 06:59 PM |
13 inch wheels won't fit over my brakes, certainly not at the front. Looking at it the 15s have a max of 2 inches clearance so it would be very
close at best.
Ill have to get 15s which is fine, it handles fine on the current ones. I may be stuck with getting some slipstreams in ET 40 and running 2mm
spacers.
Any thoughts on that please?
[Edited on 8/3/12 by Leg]
